1JTMW6410JT068450
omega_rugal
VIN : 1JTMW6410JT068450
Country : United States
Manufacturer : Jeep Corporation
Vehicle Type : Truck
Engine :  1989, 6 Cyl. 4.2 Liter / 4.0L I-6 Cyl. MPI
Powertrain : 5-speed manual, floor gear shift, 2 W/D
Line (Body Type) : Jeep Comanche, 2-W/D Pickup, 6.0' bed, 113" wheel base
Model and Gross Vehicle Weight : 4001#-5000# : Wrangler Base / Cherokee Base / Comanche Base [1815/2268 Kg]
Check Digit : 0
Year : 1988
Plant Location : Toledo, Ohio, USA
Sequential Serial Number : 068450
Check Digit Test : VIN valide
just noticed, has a Dana 44 axle
This is my Comanche, it`s green and still on the road...
  • 2 years later...
  • 1 year later...
BODY: TL61
*B1 DESCRIPTION NOT AVAILABLE -SA Charcoal AGC
APA Monotone Paint BCQ 750 Amp Maintenance Free Battery CBA Straight Back Bench Seat
CGX RR Head Restraints Outboard Seating DDJ DESCRIPTION NOT AVAILABLE ERB 4.0L I6 MPI Engine
GAC Tinted Glass Windows GSC Right Black Mirror HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes JGB Digital Clock JJA Cigar Lighter
KD8 STRIPE/BADGE/MOLDING/DELETE K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp
LMA Halogen Headlamps MDA Front License Plate Bracket NAA Federal Emissions
NHQ Transmission Heater PS4   QS4 Bright Platinum Clear Coat
SBA Power Steering TBG Compact Spare Tire WMC Open
  • 8 months later...
  • 2 years later...
2 hours ago, omega_rugal said:
update
is gone, some idiot crashed on it while it was parked, total loss, i got the equivalent to $1,200 dollars as compensation... adios vaquero
i have no comanche now i have nothing more to share here
comradery and knowledge are worth sharing :L:    ownership was never a requirement for membership. :D
bummer about the truck though. :(  that sucks.
i know but without the real thing at hand, i could only share my experiences with it, my frustratd plans...if only i could find a 4 cylinder, 4 speed, 2wd, bare bones, it could be my new fresh canvas... or a metric ton
btw is still in the county yard, and probably will stay there for a long time
go find another. :L:  you know you want to. :D
