99 Xj Grille Guard on 88 Mj?
I found a grill guard off a 99 Xj
that id like to put on my 88 Mj. The
vendor selling it is giving me a hard
time because they insist it will not
fit. For the life of me, other than
possibly the shape of the bumper i can't
see a reason why it wouldnt just bolt
on... any thoughts?
No, they list 87-95 as one part# and 97-up
as another woth no applications for Mjs.
This is an afternarket winch bumper which
mounts to the frame. Other than the plastic
bumper i can't imagine what would be different
between a 99 an 89 under the bodywork.
I need to decide by 5pm today or i lose the
discount...
Okay, deal is done - here's the details...
just bought a Warn Trans4mer #PN39637 Grill Guard
from Rustys Offroad. Both Warn and Rustys say this
thing will not fit my Mj. For those unframilar,
the Trans4mer mounts directly to the frame and
up in front of the bumper. No body work (except
maybe for the valance like Stroker mentioned) is
affected by this bar so I have no idea why it
wouldnt mount to the older truck... though part of
me thinks Rustys and Warn both know what their
talking about...
So... last request on this one... can anyone think
of why this wouldnt work? Or of what I may need to
make it work? Ill update when it gets here next
week... Thanks in advance!
That, and they also got a really bad wrap
from the hardcore off roaders for being way
too light duty for serious off roading. For
someone like me, the ability to pull myself
out of a snowbank or soft shoulder is about
the limit of what i need, but if youre
climbing rocks the Trans4mer had a tendency
of ripping itself off the frame. ARB jumped
ahead with their bullet-proof full carrier,
but i still think this is the cleanest winch
bumper on the market.
This is Jeff's (Blue88Comanche) truck
with what I believe is the "correct" model
for the Mj:
for the Mj:
Man that thing is beautiful. Too bad they don't make them anymore. Then again for 600 bucks new no wonder Warn stopped making them.
Yes that warn trans4mer grille guard is for the "correct" year range for the MJ. I can't remember for sure but I think the later model had a different part number.
But I did manage to snag it and the other sections for 20% off and free shipping so that help the price sting a bit. But then again that was also when I didn't have any bills and could afford anything.....
Okay... so the guard came today and I'm hung up
on mounting it. My Mj was in a collision by the
in-between owner and it crumpled the front tabs
where the frame ends. Apparently this is where
the Trans4mer system mounts. The other issue
might be the triangle bumper mounts themselves.
I don't know how the 97+ bumper mounts, but the
Mj uses brackets that attach to the side of the
aformentioned frame tabs. This system requires
an additional brace to be mounted between the
bracket and the frame - meaning the brackets
will be at least 0.5in farther apart from each
other. So far, the actual structure of the guard
looks flush with the rest of the bodywork.
Anyone looking into this system for another
vehicle be advised - the directions WARN provides
are some of the vaguest ive ever encountered.
There are four sets of bolts with different
lengths (30 total) and step four says youll use
7/16 and 1/2 for Step 4... no explination where,
or what lenghts. I have had to disassemble it
twice now...
I'm going to try to repair the frame this weekend,
Ill update for anyone interested on Monday...
you don't need that spacer plate from the factory, the grill guard bracket takes its place.
there should be a plate that goes on the inside of the bumper tab and on one the outsied, mine was bent and using after mounting hte grille guard it fixed.
12057352763_159e561b55_o.jpg2069098047581 by Blue88Comanche, on Flickr
you can kinda see the inside bracket on the passenger side, on the drivers side you can see the bumper bracket
12057059785_a6411853d5_o.jpg2074057491564 by Blue88Comanche, on Flickr
Yeah, but you need that bracket to mount
the bumper to though. Its all good, worst
case i can drill a small hole for new
bolts.
Bigger question - did you use the 1/2 or
7/16 bolts for mounting to the frame tabs?
The 7/16 fit better, and have locking
washers, but the 1/2s don't fit in the
crossmember. My hardware bag had a hole in
it so I'm not 100% sure its complete.
bolts.
I'm using the number bracket on the outside of the warn bracket. Just not using a spacer. I'm not sure what size I used, but everything had lock washers. The instructions say to drill a third hole on the bumper tabs and install a bolt there. I never got around to doing that.... perhaps that's where the 1/2" come in. I should have my bad of extra hardware, that would show what I didn't use.
Also as a heads up, the black bolts will rust...
Okay... task completed...
Apparently the damage to the front end of my
truck is not as minor as it looks. Once installed
the uprights were almost 7 inches out of true.
That being said, I used the tractor to bend in
the frame and managed to square up the tabs enough
to put it all together. End of story, the Warn PN
#39637 Trans4mer will fit on the front of the 88 Mj.
Looks good!
  • 6 years later...
