ParadiseMJ Posted June 9, 2016 Share Posted June 9, 2016 Hi folks, I want to replace the top two reverse torx bolts on my AW4. I took them out...long story...and I think I tossed them in absolute disgust. Can anyone help me out with the size of those bolts? Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2016 Share Posted June 9, 2016 I wanna say they are 3/8", but am not sure of the length. I suggest grade 8 studs rather than bolts. then you can use them as guide pins :thumbsup: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 9, 2016 Author Share Posted June 9, 2016 You may have something there. IIRC they were a tad +/- 2" (that's how precise I am). So SAE...not metric? Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2016 Share Posted June 9, 2016 pretty sure all the bellhousing bolts are standard Link to comment Share on other sites More sharing options...
Minuit Posted June 9, 2016 Share Posted June 9, 2016 As a general rule, things going into the engine block are standard thread and head. For example, the very common "11mm oil pan bolt" myth - they're actually 7/16". Link to comment Share on other sites More sharing options...
Dando Posted June 9, 2016 Share Posted June 9, 2016 Link to comment Share on other sites More sharing options...
cruiser54 Posted June 9, 2016 Share Posted June 9, 2016 Dando, I stole your great pic!!!! Link to comment Share on other sites More sharing options...
87MJTIM Posted June 9, 2016 Share Posted June 9, 2016 The white box at the top of the picture has the upper and lower bolts reversed. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 9, 2016 Share Posted June 9, 2016 Are they though? The smaller bolts are the top two engine-bellhousing bolts, thus the upper bolts. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 9, 2016 Share Posted June 9, 2016 On 6/9/2016 at 1:31 PM, gogmorgo said: Are they though? The smaller bolts are the top two engine-bellhousing bolts, thus the upper bolts. You are correct - on the engine... but in the picture, the bolts are backwards. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 9, 2016 Share Posted June 9, 2016 Could be confusing I suppose. But upper and lower makes more sense to be referring to the engine, not the photo. Especially since they have them labelled in the photo with the part numbers. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 9, 2016 Author Share Posted June 9, 2016 Thanks guys. I'd say the bolts are labeled correctly...one is the lower...because it's lower, on the tranny. One is the upper, because it's further up, on the tranny. Anyway, thank you for the info and the ideas. Great forum, just great. :thumbsup: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 9, 2016 Author Share Posted June 9, 2016 Thanks again guys. I stopped in to my local ACE hardware and picked up the bolts. Perfect fit, added a lock washer. Good to go now. BTW...yes, grade 8. Link to comment Share on other sites More sharing options...
Minuit Posted June 9, 2016 Share Posted June 9, 2016 Nah, you need grade 2. Gotta let the transmission stretch and get comfortable. :fs1: Link to comment Share on other sites More sharing options...
