Dogote Posted April 22, 2016 Share Posted April 22, 2016 I've read up a little on swapping in later model stuff for more braking. I may do that since I noticed a big hole rusted in my booster. Has anyone just bought this set up: http://www.crownautomotive.net/product/RT31037.html If so, was it any good? Link to comment Share on other sites More sharing options...
big66440 Posted April 22, 2016 Share Posted April 22, 2016 I really don't see what the advantage is over the more readily available and cheaper 95-96 XJ set up, I'm not trying to tell you how to spend your money on your vehicle but I have the 95-96 XJ set up with steel braided brake lines http://www.summitracing.com/parts/rus-694850 and my MJ's brakes are better than some newer cars, as an added bonus there's tons of info and support on this swap. To each his own though I'm just throwing in my 2 pennies worth. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 22, 2016 Share Posted April 22, 2016 How much is the Crown conversion, and is it a drop in for our trucks? Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 23, 2016 Share Posted April 23, 2016 Also curious on the crown Price, I'm unable to view the cost Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 23, 2016 Share Posted April 23, 2016 Yup aint going through the BS just to see the price... Link to comment Share on other sites More sharing options...
xjrev10 Posted April 25, 2016 Share Posted April 25, 2016 96 or newer XJ or WJ master booster is the most economical. Great write up on here for the WJ one. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 25, 2016 Share Posted April 25, 2016 It is gulp $386.86 on Amazon. A master cylinder is around $50 on RockAuto and the Booster is $70 for the later Cherokee Link to comment Share on other sites More sharing options...
Minuit Posted April 25, 2016 Share Posted April 25, 2016 Or you could pay about $30-50 at a junkyard for a 95/96 XJ unit. And then it'll be a real OEM part, not aftermarket crap. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 25, 2016 Share Posted April 25, 2016 Which MC is being used? Link to comment Share on other sites More sharing options...
xjrev10 Posted April 26, 2016 Share Posted April 26, 2016 Which MC is being used? For which one? 95-96 XJ and WJs I've always used them as a unit. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 27, 2016 Share Posted April 27, 2016 Which MC is being used?For which one? 95-96 XJ and WJs I've always used them as a unit. Inthe Crown kit? Link to comment Share on other sites More sharing options...
xjrev10 Posted April 27, 2016 Share Posted April 27, 2016 Crown? I'm missing your question I guess. Crown is a manufacture of parts for Jeeps of all vintage.. I'd never spend that much on a setup.. I probably have $350 in my complete brake system on my truck including slotted rotors, new calipers, hoses etc. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 27, 2016 Share Posted April 27, 2016 Crown? I'm missing your question I guess. Crown is a manufacture of parts for Jeeps of all vintage.. I'd never spend that much on a setup.. I probably have $350 in my complete brake system on my truck including slotted rotors, new calipers, hoses etc. I guess what I want to know is how to replicate what crown sells with off the shelf parts. Link to comment Share on other sites More sharing options...
xjrev10 Posted May 1, 2016 Share Posted May 1, 2016 Crown? I'm missing your question I guess. Crown is a manufacture of parts for Jeeps of all vintage.. I'd never spend that much on a setup.. I probably have $350 in my complete brake system on my truck including slotted rotors, new calipers, hoses etc. I guess what I want to know is how to replicate what crown sells with off the shelf parts. The other options above are listed. 95-96 XJ is bolt in. WJ stuff takes a little extra effort. Both the options I listed can be done for less then $100. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 1, 2016 Share Posted May 1, 2016 Crown? I'm missing your question I guess. Crown is a manufacture of parts for Jeeps of all vintage.. I'd never spend that much on a setup.. I probably have $350 in my complete brake system on my truck including slotted rotors, new calipers, hoses etc. I guess what I want to know is how to replicate what crown sells with off the shelf parts.The other options above are listed. 95-96 XJ is bolt in. WJ stuff takes a little extra effort. Both the options I listed can be done for less then $100. Thanks! So...just to be sure: I can take a '95 MC and booster and bolt it into my '87 with no other mods? Link to comment Share on other sites More sharing options...
xjrev10 Posted May 2, 2016 Share Posted May 2, 2016 Correct. The problem with others is your brake light switch and you must modify the firewall. (With a hammer just like any other jeep mod) I have a WJ master/booster and did NOT swap out the prop valve. I eliminated the load sensing valve and plugged the hole for it on the prop valve. With rear discs, my truck stops perfect. Link to comment Share on other sites More sharing options...
