FireManDango Posted June 25, 2016 Share Posted June 25, 2016 seems like the perfect excuse for a long arm kit ;) Link to comment Share on other sites More sharing options...
4.0forlife Posted June 26, 2016 Author Share Posted June 26, 2016 You might be on to something there Link to comment Share on other sites More sharing options...
FireManDango Posted June 26, 2016 Share Posted June 26, 2016 Check out what Clayton has. http://www.carid.com/clayton-off-road/xj-auto-mpn-4801512.html?gclid=CICMkYmbxs0CFUEkhgods5YCZw That's what I'm looking into. Prob going to fab my own arms and just get builder parts but the center piece is nice. Don't need to drop the whole long arm kit to get to the tranny. I've done a decent amount of research and almost time for me to pull the trigger. I've been lurking around on this forum for a while and will more than likely be making a build post but prob won't start in until I'm pretty far in cause I'll be working at a snails pace haha Good luck man! Link to comment Share on other sites More sharing options...
4.0forlife Posted June 28, 2016 Author Share Posted June 28, 2016 Huh so that takes the place of the factory crossmember and locates the arms to the x member. Looks decent but if I'd have to change the clutch wouldn't my axle want to walk around? If the crossmember is down the lowers aren't holding anything still. Correct? Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 28, 2016 Share Posted June 28, 2016 Huh so that takes the place of the factory crossmember and locates the arms to the x member. Looks decent but if I'd have to change the clutch wouldn't my axle want to walk around? If the crossmember is down the lowers aren't holding anything still. Correct? Most long arm kits are like that. It can be a pain but there is workarounds. Link to comment Share on other sites More sharing options...
4.0forlife Posted June 29, 2016 Author Share Posted June 29, 2016 I'll have to look into it a little later down the road Link to comment Share on other sites More sharing options...
4.0forlife Posted July 16, 2016 Author Share Posted July 16, 2016 well its been a roller coaster of a ride with the jeep. i did a sye kit and had to drive in front wheel drive till i got my adams driveshaft. i developed a power steering leak and an oil leak. then my starter gave up the ghost on the 4th of July. and now after knowing i have needed a speedometer cable for a month, i lost the speedometer. from the cable binding in the sleeve it put enough pressure on the gear in the t-case which blew all the teeth off the gear. with all this going on i found my cross member bolts had started to strip out. so i re-tapped the nutserts to 7/16-14 and drilled the others out and nut and bolted them in. Link to comment Share on other sites More sharing options...
4.0forlife Posted July 16, 2016 Author Share Posted July 16, 2016 just some back log photos Link to comment Share on other sites More sharing options...
Steve Gregory Posted July 20, 2016 Share Posted July 20, 2016 This is a great build!! Link to comment Share on other sites More sharing options...
4.0forlife Posted July 27, 2016 Author Share Posted July 27, 2016 well guys i got my new cable and gear for the speedometer. but i still have a lot of cable bounce. I'm wondering if i have a bad speedometer. i chucked the cable in a drill and it still bounced so i have no clue. does anyone know anything i can try? thanks for all the compliments guys. Link to comment Share on other sites More sharing options...
TONIO_MJ Posted July 29, 2016 Share Posted July 29, 2016 I didn't want a bench in my MJ so I went to Craigslist and ther was a 96 Cherokee for parts and I took his manual seats and power doors for $120 I did have to get brackets custom made but was very cheap that sit perfect now.work great and look great Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 30, 2016 Share Posted July 30, 2016 well guys i got my new cable and gear for the speedometer. but i still have a lot of cable bounce. I'm wondering if i have a bad speedometer. i chucked the cable in a drill and it still bounced so i have no clue. does anyone know anything i can try? thanks for all the compliments guys. Swapping the speedo is pretty easy if you have another cluster to pull one out of. It's just in there with screws. Link to comment Share on other sites More sharing options...
4.0forlife Posted July 30, 2016 Author Share Posted July 30, 2016 Wenter to the junkyard today. And got a whole cluster. Swapped it in the trunk and still bounced. Ended up that it was my cable routing I guess. So I moved it so the cable is a bit smoother and the turns flow a bit better. Well see how it works. Also I had a high idle/stalling issue. I determined it to be the tps. Wow did I have sticker shock. 110 for the tps and 60 for the iac valve. Swapped in the tps using cruiser54s tips and so far the truck is 99% better. Link to comment Share on other sites More sharing options...
Rockfrog Posted July 30, 2016 Share Posted July 30, 2016 That's why I converted to the GM 86-94 (Standard Th32) 2.8L TPS. Cheap and only takes a simple wire swap in the connector. Been running one for about a year now (maybe closer to two can't remember). Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 31, 2016 Share Posted July 31, 2016 Or buy a TPS for the automatic. Works exactly the same but way cheaper... $40 on average. Link to comment Share on other sites More sharing options...
Rockfrog Posted July 31, 2016 Share Posted July 31, 2016 Last I checked the GM TPS was $21 on rockauto. So even cheaper yet. Easily reversible conversion. But, it was just a suggestion anyway. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
4.0forlife Posted July 31, 2016 Author Share Posted July 31, 2016 Man I should have asked first. But all well live and learn Link to comment Share on other sites More sharing options...
4.0forlife Posted August 5, 2016 Author Share Posted August 5, 2016 so after i swapped my sensors all was well, or i thought so. started it yesterday and it shot to 3k and sat there. unplugged the iac and plugged it back in, went back down so idk what thats about. Link to comment Share on other sites More sharing options...
Rockfrog Posted August 9, 2016 Share Posted August 9, 2016 Check the condition/function of the "Latch Relay" ... It's function is to supply power to reset the IAC on shutdown. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
chief6602 Posted August 16, 2016 Share Posted August 16, 2016 Great looking truck! Can't wait to get started on mine. Link to comment Share on other sites More sharing options...
G O B Posted August 16, 2016 Share Posted August 16, 2016 Good build, and YES some of us are reading! Link to comment Share on other sites More sharing options...
4.0forlife Posted August 22, 2016 Author Share Posted August 22, 2016 well guys i went to go to work last Tuesday and found my pitman arm seal seal let loose lucky my local napa got the seals in the same day for me. friday i did my wiper trans. bushings. also the over the weekend i had to replace my ball joints. while i was at it i replaced the lower control arms with some rough country ones. i forgot to take pics. Link to comment Share on other sites More sharing options...
4.0forlife Posted August 27, 2016 Author Share Posted August 27, 2016 i got tired of my spare 33 laying in the back on the bed so i got ambitious this weekend and decided to make a carrier for it i could have spent a little more time on it but the humidity was killing me so good enough for now. Link to comment Share on other sites More sharing options...
4.0forlife Posted September 6, 2016 Author Share Posted September 6, 2016 well guys i took some days off work so i could get some things done that ive been neglecting on the jeep. so with out further ado i give you... \ finally mounted on my krustyballer sliders. i tried the whole nutsert thing and it ripped them out so i broke the arch welder out and stitched them on. Link to comment Share on other sites More sharing options...
4.0forlife Posted September 6, 2016 Author Share Posted September 6, 2016 i also did away with my sloppy steering and upgraded to some heavy duty goodness. it took me a little bit to figure it out but i got it on and she steers great! iron rock offroad makes an awesome setup and i only got the 1/2 bolt version because i wanted to be able to revert back to stock if i wanted. Link to comment Share on other sites More sharing options...
