Tom_Comanche_G Posted February 8, 2016 Posted February 8, 2016 i am trying to achieve a non tapered comanche with s.o.a. the way i bought my comanche was with a 4.5" lift spring under axel and now going ontop makes it way to big. Changing the shackle to an stock xj one does not help either. I think i need to find a stock comanche leaf spring? Any info would be much appreciated and possibly the whereabouts of finding stock comanche leaf springs in the vancouver area.
HOrnbrod Posted February 8, 2016 Posted February 8, 2016 non tapered? :hmm: http://www.generalspringkc.com/product_p/97-555.htm
Pete M Posted February 8, 2016 Posted February 8, 2016 I believe he means he wants a level truck rather than a raked look. HellCreek and General Spring make new ones. car-part.com can help find old ones in junkyards.
mikekaz1 Posted February 15, 2016 Posted February 15, 2016 why even bother going SOA if you don't want it bigger then it already is? seems like wasted cost to me,,,,
87mjdriver Posted February 17, 2016 Posted February 17, 2016 I just bought a set of stock springs from General spring. Super fast delivery. good quality good price. What height are you shooting for? pay attention to how tall your new spring perches are, I didn't and got some that are a bit taller than stock type and my SOA came out to 8 inches.
mikekaz1 Posted February 17, 2016 Posted February 17, 2016 semi off topic... but what is the benefit of spring over anyways? other then ground clearance?
Pete M Posted February 17, 2016 Posted February 17, 2016 staying SUA maxes out at around 4.5" of lift so if you want anything more, you really only have one choice.
mikekaz1 Posted February 18, 2016 Posted February 18, 2016 Ah OK. So there's no true(performance) benefit or gain? It just allows a higher lift ability.
gogmorgo Posted February 18, 2016 Posted February 18, 2016 There is still an improvement in ground clearance over stock. Moving the axle to the other side of the springs also means the spring plate moves above the axle, so all you have below it is the u-bolts.
Incommando Posted February 18, 2016 Posted February 18, 2016 As mentioned it helps because it moves stuff that will get hung up on things above the axle. It also allows you to use flatter leafs then what would be needed from a SUA to get the same lift. High arches take away from flex.
89eliminator Posted February 18, 2016 Posted February 18, 2016 Ah OK. So there's no true(performance) benefit or gain? It just allows a higher lift ability. false. getting to use the stock leaf packs results in a smoother ride and better off road performance. the flatter the leaf pack arch, they better. there is a drawback though, and that is a greater chance for axle wrap. when i was still on leaf springs, i had to fab a traction bar because my axle wrap was so bad.
mikekaz1 Posted February 19, 2016 Posted February 19, 2016 Ah OK. So there's no true(performance) benefit or gain? It just allows a higher lift ability. false. getting to use the stock leaf packs results in a smoother ride and better off road performance. the flatter the leaf pack arch, they better. there is a drawback though, and that is a greater chance for axle wrap. when i was still on leaf springs, i had to fab a traction bar because my axle wrap was so bad. eh... still seems like no solid benefit to it other then ground clearance and lift ability, what you explained as an improvement is more of it just gives the ability to keep using factory parts, that themselves have a better ride vs aftermarket. but not that the SOA itself has a benefit in ride or drivability, but just that factory springs are a better ride (usually). and it gives the added disadvantage of axle wrap.
