Mj4life Posted January 27, 2016 Share Posted January 27, 2016 So I did my injectors last night, upgraded my injectors from the single port to the 4port injectors and now it feels like its flooding the motor with fuel. Not sure what it is, maybe from priming the motor a little too much? Link to comment Share on other sites More sharing options...
NorthWoods Posted January 27, 2016 Share Posted January 27, 2016 Check your timing Link to comment Share on other sites More sharing options...
Mj4life Posted January 27, 2016 Author Share Posted January 27, 2016 On 1/27/2016 at 3:28 PM, NorthWoods said: Check your timing Cap and rotor? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 27, 2016 Share Posted January 27, 2016 So I have some questions. 1. What year/engine is your truck? 2. Which injectors did you use? 3. What does "priming the motor a little too much" mean? 4. What do you mean when you say "it feels like its flooding the motor with fuel"? Fuel pouring out somewhere? Link to comment Share on other sites More sharing options...
Mj4life Posted January 27, 2016 Author Share Posted January 27, 2016 On 1/27/2016 at 4:16 PM, hornbrod said: So I have some questions. 1. What year/engine is your truck? 2. Which injectors did you use? 3. What does "priming the motor a little too much" mean? 4. What do you mean when you say "it feels like its flooding the motor with fuel"? Fuel pouring out somewhere? 1987/4.0 Have to see but a guy I know has them, haven't heard from him. And exactly when I meant. Maybe I primed the motor too much and too much fuel went I to the cylinders And when I drive it, its running like it wants to shut off. I have smoke coming from the exhaust and smells like gas. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 27, 2016 Share Posted January 27, 2016 Check the vacuum line between the throttle body and the Map sensor. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 27, 2016 Share Posted January 27, 2016 The injectors should be stamped with a p/n on the body. W/o knowing which injectors you put in and their psi and flow ratings who knows what's going on. Any external fuel leaks? Are you sure the injectors electrical connectors are not crossed? Link to comment Share on other sites More sharing options...
Mj4life Posted January 27, 2016 Author Share Posted January 27, 2016 On 1/27/2016 at 5:20 PM, ComancheKid45 said: Check the vacuum line between the throttle body and the Map sensor. I'll look there's when I have it in my shop tonight. Link to comment Share on other sites More sharing options...
Mj4life Posted January 27, 2016 Author Share Posted January 27, 2016 On 1/27/2016 at 5:22 PM, hornbrod said: The injectors should be stamped with a p/n on the body. W/o knowing which injectors you put in and their psi and flow ratings who knows what's going on. Any external fuel leaks? Are you sure the injectors electrical connectors are not crossed? I will look at the injectors while I look for a vacume leak. What should the psi be for the injectors? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 27, 2016 Share Posted January 27, 2016 If your engine is stock, you want injectors with specs close to the stock injectors, ~19 lb/hr @ 39psi. Anything higher is a waste. The main reason for "upgrading" fuel injectors is supposedly for better flow / atomization the newer 4-port injectors provide over the stock single port type. Link to comment Share on other sites More sharing options...
Zebvance Posted January 27, 2016 Share Posted January 27, 2016 On 1/27/2016 at 3:28 PM, NorthWoods said: Check your timing Unless I'm mistaken, The renix 4.0 has non adjustable timing. Link to comment Share on other sites More sharing options...
NorthWoods Posted January 27, 2016 Share Posted January 27, 2016 You would want to follow cruisers tip at cruiser54.com to set the clocking of your distributer. Link to comment Share on other sites More sharing options...
NorthWoods Posted January 27, 2016 Share Posted January 27, 2016 I believe that anyone who has never done that to their renix would be surprised by the results. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 28, 2016 Share Posted January 28, 2016 On 1/27/2016 at 5:20 PM, ComancheKid45 said: Check the vacuum line between the throttle body and the Map sensor. Yowza. Always seems to get broken in the injector replacement process. Seen my new Tip on that at www.cruiser54.com? Link to comment Share on other sites More sharing options...
oldgoat Posted January 30, 2016 Share Posted January 30, 2016 Second that, a hairline crack in the old brittle tubing causes all kinds of trouble. Link to comment Share on other sites More sharing options...
Francesco Posted January 30, 2016 Share Posted January 30, 2016 I know when I did my 703 Injector Swap on my '90, it ran like complete @$$, whenever I would give it gas, it would stumble, etc. Ended up being the tube that everyone is talking about here. Link to comment Share on other sites More sharing options...
