Mj4life
1011 profile views
Mj4life's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I will look at the injectors while I look for a vacume leak. What should the psi be for the injectors?
  2. I'll look there's when I have it in my shop tonight.
  3. 1987/4.0 Have to see but a guy I know has them, haven't heard from him. And exactly when I meant. Maybe I primed the motor too much and too much fuel went I to the cylinders And when I drive it, its running like it wants to shut off. I have smoke coming from the exhaust and smells like gas.
  4. Cap and rotor?
  5. So I did my injectors last night, upgraded my injectors from the single port to the 4port injectors and now it feels like its flooding the motor with fuel. Not sure what it is, maybe from priming the motor a little too much?
  6. If you do that for side work and decide to do it for others let me know. I'll send you my tail lights and have you do them while I am away at bootcamp.
  7. Brackets from the bench seats wouldn't fit on the bucket seats of a newer jeeps? Figured they would work unless the mounting holes on the sliders are different.
  8. There has been one person that has definitely did a extended cab mj but I believe he's not on this site. He used a xj front end and used the mj rear. He welded them together and made it stronger.
  9. Grind down the rivets of the brackets under the bench seats. Use a hammer and chisel to separate the brackets from the bench seats. There are spot welds that also hold the brackets to the seat frames so get ready to either use a drill to get them off or man handle them which I did. And then use a dolly to straighten them out. Then vise versa for the bucket seats.
  10. Mike that looks awesome still, great work.
  11. Most likely going to use the first tire carrier from the first link johnj put.
  12. That would be great, thank you.
  13. Just taking me to the home page. Wasn't sure if someone had a tire carrier from the xj (factory carrier) and made something to fit the mjs.
  14. Thinking of mounting my spare tire on the back end behind the tailgate rather then under the bed or in the bed. Is there a DIY without welding that someone has done for a spare mount?
  15. Mj4life
    Pine barrens
    Taking a trip to the pines on sunday after this holiday, want to get out when the weather is nice. Anyone want to go?
