jbuds690 Posted October 23, 2015 Share Posted October 23, 2015 So my old pump was wobbling and went on my way home just put a new one in and I can only get a half spin out of it. Wasn't sure if anyone has any decent ideas to help. No I'm not a matter mechanic but I know my way around so please no smart assing. Its 87 with the 4.0 Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted October 23, 2015 Share Posted October 23, 2015 There should be A slight drag . If it seems excessive go compare it with another one from the parts store . Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 No drag just completely stops it's brand new Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted October 23, 2015 Share Posted October 23, 2015 It seems like one of the fins may have gotten bent and is hitting the housing , or a bad bearing . Another thing I would check is that the pulley and or pulley bolts aren't making contact with anything . Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 23, 2015 Share Posted October 23, 2015 Did you check for free spin before installing it? Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 Thanks I'll have to take a look when I get there I still gotta take it back off it was getting dark yesterday and it's not at the easiest place for me to work on Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 Yes it spun fine Link to comment Share on other sites More sharing options...
yxmj Posted October 23, 2015 Share Posted October 23, 2015 Did you use a gasket or rtv? Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 Both ran a small bead of rtv on the cardboardish gasket Link to comment Share on other sites More sharing options...
yxmj Posted October 23, 2015 Share Posted October 23, 2015 It is going to have to come off.....dry fit it this time when you put it on (no rtv or gasket) finger tighten the bolts and spin it from time to time until you feel it starting to jamb on something...twist it gently back and forth a couple of times and then take it off...maybe you can see were it is rubbing. And with all do repect.....it is the correct pump..... . :MJ 1: . ....right? Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 It is going to have to come off.....dry fit it this time when you put it on (no rtv or gasket) finger tighten the bolts and spin it from time to time until you feel it starting to jamb on something...twist it gently back and forth a couple of times and then take it off...maybe you can see were it is rubbing. And with all do repect.....it is the correct pump..... . :MJ 1: . ....right? Will do thanks and it looks like the same one. I mean it wouldn't be the first time Napa have me the wrong part of it was Link to comment Share on other sites More sharing options...
jbuds690 Posted October 23, 2015 Author Share Posted October 23, 2015 And sorry about all the spelling mistakes yall appreciate the help Link to comment Share on other sites More sharing options...
metrictonner Posted October 24, 2015 Share Posted October 24, 2015 The pipe that screws into the right side of the water pump goes right down to the blades. Did something fall down into it? Link to comment Share on other sites More sharing options...
xjrev10 Posted October 29, 2015 Share Posted October 29, 2015 So my old pump was wobbling and went on my way home just put a new one in and I can only get a half spin out of it. Wasn't sure if anyone has any decent ideas to help. No I'm not a matter mechanic but I know my way around so please no smart assing. Its 87 with the 4.0 No need to worry about flaming here. Link to comment Share on other sites More sharing options...
jbuds690 Posted October 29, 2015 Author Share Posted October 29, 2015 Thanks I fixed it. Turns out the bolts to hold the pulley on the pump were too long Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 31, 2015 Share Posted October 31, 2015 Thatll do it....Glad you figured it out :thumbsup: Link to comment Share on other sites More sharing options...
