wutangwisdom Posted June 22, 2015 Posted June 22, 2015 Planning on replacing my pcv valve/ front and back vacuum harnesses since i looked down the hoses with a flashlight and its caked with oil front and back harness both. I have read its smarter to just take the whole valve cover off to do this repair. I'm planning on doing that as plan B. does the pcv thread in? Or is it pressed into the gromet. sorry for another noob DIY I have read up on it and looking at the replacement pcv valve I just can't picture how it is installed. Metal end inside the valve cover plastic part connects to the vacuum. Is there a certan direction the metal part should be facing while its installed ( facing the firewall or facing the front doesnt matter?) Sorry for the noob question just having trouble finding a little more detailed write up, besides cruisers
Strokermjcomanche Posted June 22, 2015 Posted June 22, 2015 Get yourself a Haynes / chilton or full service manual (FSM ) , a very good investment and you don't have to wait on answers .
wutangwisdom Posted June 22, 2015 Author Posted June 22, 2015 ok... sorry again guess there is no pcv on a 4.0 correct I will just get the 2 harnesses and see if I can get the nipple out and back in without it snapping
Rockfrog Posted June 22, 2015 Posted June 22, 2015 IIRC ... You have a Renix, the rear nipple/hose assemvly simply pops out. Careful not to snap it. The front one is a molded part of the front Vacuum harness. If you take the valve cover from a later model motor and swap that on ... you upgrade to the later style CCV which was less clog prone (due to larger orifice and hose size). The 96 and later valve covers used the least problematic style with parts still readily available cheaply. Search here for 'Vacuum Harness' and it should bring up a series of Dorman part numbers to order to replace the complete Vacuum Harness/CCV system. A further bit of searching will also net some actual CCV to PCV conversions as well, simple, but no more effective as they both do essentially the same thing.
Blue88Comanche Posted June 22, 2015 Posted June 22, 2015 check my signature for PDF Manuals and Jeep part catalogs
sinkrun Posted June 22, 2015 Posted June 22, 2015 Do yourself a favor and do some reading on the the never valve cover swap it more than worth it. Theres lot of threads on it here, if you can't find them I will try when I have more time tonight. Might also google renix valve cover swap to find some more info.
wutangwisdom Posted June 22, 2015 Author Posted June 22, 2015 I will do this when I get home from work thanks a lot for the manuals also
cruiser54 Posted June 23, 2015 Posted June 23, 2015 Or, click on the link below and see my Tips 22 and 25.
