Strokermjcomanche Posted April 25, 2015 Share Posted April 25, 2015 I recently purchased an external slave ax15 with 231 tcase out of a yj for a swap from a 2wd ba10 to convert my 89 mj to 4wd . Of course now I found a nv3550 and tcase with 89 k miles on it for $500 out of an 02 Tj . What are the advantages / disadvantages of each trans ? I know that on both the tcase will have to be clocked to fit the mj . I've done some reading but can't seem to find much info putting the nv3550 in a mj . Thanks in advance . Link to comment Share on other sites More sharing options...
Pete M Posted April 26, 2015 Share Posted April 26, 2015 I've got a 00 TJ AX-15 in my 88 and I feel the extra clocking is a good thing. :D more ground clearance! I have a custom crossmember though. whatever you do, don't use a peugeot or aw4 crossmember. either go custom or find an AX-15 one. The AX-15 has a drop in the center of it that lowers the trans a bit. for me it was the linkage that needed some customization, but I think if you get stock MJ stuff it'll work fine. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 26, 2015 Author Share Posted April 26, 2015 Did you have to make clearance in the floor for the tcase ? What would you think about putting the nv3550 in? Link to comment Share on other sites More sharing options...
mnkyboy Posted April 26, 2015 Share Posted April 26, 2015 Everything i've found shows the maximum torque rating to be about the same,i don't see an advantage to one over the other. Link to comment Share on other sites More sharing options...
Pete M Posted April 26, 2015 Share Posted April 26, 2015 it's close, but doesn't touch. :thumbsup: but as I said, I have a custom crossmember (though it is a high ground clearance crossmember which in theory works against me). My inclination is to think that some people aren't using the AX-15 crossmember and the other ones would raise it up an inch or 2, but don't have proof on that yet. maybe someone else that has done the wrangler swap can comment. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks for the replies . Not sure what I want to do yet , I guess time will tell.. Link to comment Share on other sites More sharing options...
Eagle Posted April 26, 2015 Share Posted April 26, 2015 I have a 2000 XJ with the 3550, and I have an AX-15 in one of the '88 MJs. There is no comparison. First, the 3550 has a deeper first gear, so if you go off-road that helps your crawl ratio. The 3550 is MUCH smoother shifting, and it's quieter when driving. If you can get it for $500 -- go for it. Link to comment Share on other sites More sharing options...
mnkyboy Posted April 26, 2015 Share Posted April 26, 2015 Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 27, 2015 Share Posted April 27, 2015 Didn't JP Mag do this swap (3550) on an MJ? Think I only saw the first part, think second part was going to show how to deal with the electronic speedo drive? Link to comment Share on other sites More sharing options...
xjrev10 Posted April 27, 2015 Share Posted April 27, 2015 Didn't JP Mag do this swap (3550) on an MJ? Think I only saw the first part, think second part was going to show how to deal with the electronic speedo drive? They did a NSG 370 6-speed. Little less robust then the ax15 or nv3550 but pegs the cool factor meter. Link to comment Share on other sites More sharing options...
87Warrior Posted April 27, 2015 Share Posted April 27, 2015 The 3550 is MUCH smoother shifting, and it's quieter when driving. I completely agree with you, Eagle. The 3550 in my TJ provides a much more pleasant driving experience over the previous AX15 vehicles I have had. At 130K miles mine still shifts like butter. The 3550 will sometimes have a slight rattle, like soft marbles rolling around, when the vehicle is idling in neutral. Link to comment Share on other sites More sharing options...
