shelbyluvv Posted April 16, 2015 Share Posted April 16, 2015 On the left side of the trans tunnel (looking at the pic) there is an oval hole. I have no idea what went through there and I still have a open hole there. This allows a good amount of water to come in the cab. Where can I find a plug to fit that hole? Link to comment Share on other sites More sharing options...
yxmj Posted April 16, 2015 Share Posted April 16, 2015 Can't really see from the pic .....but would it be the same size as the "plugs" used as drains in the floor pans? Link to comment Share on other sites More sharing options...
mjeff87 Posted April 16, 2015 Share Posted April 16, 2015 That's where the TCU wiring harness runs on autos. I'd check a junkyard for any manual XJ/MJ, there's a hard rubber plug that goes there on manuals. Link to comment Share on other sites More sharing options...
sinkrun Posted April 16, 2015 Share Posted April 16, 2015 Maybe this ?, http://www.ebay.com/itm/S-04586055-Omix-Ada-Floor-Pan-Drain-Plug-Jeep-Wrangler-TJ-Cherokee-XJ-1984-2006-/201124003973?fits=Model%3ACherokee&hash=item2ed3ecc085&vxp=mtr Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 16, 2015 Author Share Posted April 16, 2015 Makes sense. Thanks Jeff! Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 16, 2015 Share Posted April 16, 2015 Pretty sure I have one . I have to check .And when you say left ,driver or passenger . Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 16, 2015 Author Share Posted April 16, 2015 Passenger side Adam beside the HVAC line hole. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 16, 2015 Author Share Posted April 16, 2015 The weird part is I have torn apart a bunch of X/MJs and never knew that the standard shift had a plug in that hole. I learned something new today. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 16, 2015 Share Posted April 16, 2015 http://teamcherokee.com/floor-pan-plug-set-oem-cherokee-1997-2001/ Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 16, 2015 Share Posted April 16, 2015 Ok when I get home I'll check . Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 16, 2015 Author Share Posted April 16, 2015 That's not them Don. it is a hard, oval rubber plug. Link to comment Share on other sites More sharing options...
Jeepman Posted April 16, 2015 Share Posted April 16, 2015 I am pretty sure this is the OE Part number for what you want... 3420 2215 Image Not Found Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 16, 2015 Share Posted April 16, 2015 That's not them Don. it is a hard, oval rubber plug. Hole dimensions? (approx). I have quite a few rubber oval plugs. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 16, 2015 Author Share Posted April 16, 2015 Got one on the way. Thanks again to the amazing Adam! Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 16, 2015 Share Posted April 16, 2015 :thumbsup: Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 16, 2015 Share Posted April 16, 2015 Got one on the way. Thanks again to the amazing Adam! What can I say , I'm a pack rat and throw nothing away lol, Link to comment Share on other sites More sharing options...
