Brunner Posted March 1, 2015 Share Posted March 1, 2015 Hey guys, my comanche came stock with overload springs and metric ton badges. I'm asking how can I Tell if i have the D44 in the rear Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted March 1, 2015 Share Posted March 1, 2015 Do you have a picture of the diff cover ? There is an informative picture thread that has pics of all the diff covers identifiying what axles you have. Link to comment Share on other sites More sharing options...
Brunner Posted March 1, 2015 Author Share Posted March 1, 2015 Right on I'll find that picture with all the diff covers Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted March 1, 2015 Share Posted March 1, 2015 Just bumped it for you . Link to comment Share on other sites More sharing options...
Incommando Posted March 1, 2015 Share Posted March 1, 2015 Google "Dana 44 diff cover" and compare the shape to yours Link to comment Share on other sites More sharing options...
dunnc1991 Posted March 2, 2015 Share Posted March 2, 2015 This one has a lot more then just jeep axles, but this covers it. Link to comment Share on other sites More sharing options...
Incommando Posted March 2, 2015 Share Posted March 2, 2015 Just in case you didn't know the factory choices are the two on the top row and furthest to the right: Dana 35 & Dana 44. But nothing is assured on a 25 year old jeep. ( In just noticed that at some point or another in have had 8 of the 16 options on that chart in a jeep.) Link to comment Share on other sites More sharing options...
gogmorgo Posted March 2, 2015 Share Posted March 2, 2015 Actually all of the ones in the top row were available for the MJ at one time from the factory. The AMC 20 was the heavy-duty rear axle option for the '86 model year, and it somewhat rare as originally set up for the MJ. The Dana 30 was the only front axle available under an MJ. The Dana 35 was the standard rear axle for all MJ's. The Dana 44 was the heavy-duty rear axle option for '87 and up. It's also fairly rare, but not quite to the same extent as the AMC 20. The heavy-duty rear axle was part of both the Metric Ton (Big Ton), and offroad packages, but could also be optioned separately. Link to comment Share on other sites More sharing options...
Incommando Posted March 2, 2015 Share Posted March 2, 2015 My '88 SWB with the factory tow package had a factory D44. Link to comment Share on other sites More sharing options...
mvusse Posted March 2, 2015 Share Posted March 2, 2015 It was part of the towing package, but I don't think it was part of the offroad package. I have seen a number of MJs with full skid plates (including gas tank) that had a 35 under it. Link to comment Share on other sites More sharing options...
Bobolink Posted March 2, 2015 Share Posted March 2, 2015 It was also part of the heavy ton/metric tonne package, if his MT springs are original stock, he probably has the D44. Link to comment Share on other sites More sharing options...
JeepsOLot Posted March 8, 2015 Share Posted March 8, 2015 Looks like my '86 had a D44 originally, doesn't look like it was messed with in 28 years! I was surprised, it's a Custom that had the 2.8 in it, thought it should have had an AMC 20 as well. Jerry Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 8, 2015 Share Posted March 8, 2015 Looks like my '86 had a D44 originally, doesn't look like it was messed with in 28 years! I was surprised, it's a Custom that had the 2.8 in it, thought it should have had an AMC 20 as well. Jerry 86 models never came from the factory with a D44. All HD axles were AMC-20's with either a 3.31, 3.54/3.55, or 4.11 ratio. Link to comment Share on other sites More sharing options...
Incommando Posted March 8, 2015 Share Posted March 8, 2015 Looks like my '86 had a D44 originally, doesn't look like it was messed with in 28 years! I was surprised, it's a Custom that had the 2.8 in it, thought it should have had an AMC 20 as well. Jerry 86 models never came from the fatory with a D44. All HD axles were AMC-20's with either a 3.31, 3.54/3.55, or 4.11 ratio. And the AMC looks nothing like either Dana. Link to comment Share on other sites More sharing options...
JeepsOLot Posted March 9, 2015 Share Posted March 9, 2015 Well, here is what's under my '86 MJ which originally had the 2.8 and Torque Flite tranny. Image Not Found You be the judge. Jerry Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 9, 2015 Share Posted March 9, 2015 That's a 44 alright. What is the 10th character of your VIN number? Link to comment Share on other sites More sharing options...
JeepsOLot Posted March 9, 2015 Share Posted March 9, 2015 10th character in the VIN is a "G". Jerry Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 9, 2015 Share Posted March 9, 2015 Definitely an 86 MJ VIN then, and in looking how the brake lines are configured and bent, your D44 sure looks original and factory as can be. Especially with the MT badging you said was present. Another case maybe of never say never when it comes to MJs. I'm convinced it's original based on your pics. Maybe a late build date for your rig? BTW, the arm of your brake load sensing valve is wrong - should be configured like this, roughly parallel to the axle: Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted March 9, 2015 Share Posted March 9, 2015 It looks like the load sensing arm has been messed with , could it have been changed at one point ? After all it is a 29 years old . Link to comment Share on other sites More sharing options...
Incommando Posted March 9, 2015 Share Posted March 9, 2015 It looks like the load sensing arm has been messed with , could it have been changed at one point ? After all it is a 29 years old . good point Link to comment Share on other sites More sharing options...
JeepsOLot Posted March 9, 2015 Share Posted March 9, 2015 I haven't done anything with the load sensing arm, it's how I bought it. It doesn't have MT badging, nor does it have MT springs, I'm told. I believe it is a late production '86, would make sense. I'm not keeping this one, as I got an 88 Eliminator, and it's more of what I want and I don't have to do a motor/tranny transplant. Definitely, the D44 is going under the Eliminator, and the D35 under the '86 before it leaves me. Jerry Link to comment Share on other sites More sharing options...
