westypoo Posted February 21, 2015 Share Posted February 21, 2015 i have a 92' 2wd long bed Comanche and I'm gonna convert to 4wd here soon. but i figure wile doing that, i might as well get a lift on it. been looking around at lift kits. i want to just cry once and do it right the first time. my truck will be mostly a daily driver and summer time off-road trails around colorado/utah (Imogene pass, Engineer pass and moab for example). right now i have 31's on it on OE wheels/ stock hight. ive been looking at the Rough Country 4.5 long arm kit for a xj. i know the rear is different, but ive thought about a SOA in the rear. I'm fairly handy in the fabing deperment as i do a lot with my other car (vw bug). so with all this said, do i need a long arm kit, is it worth having? they seem to obviously flex better, do they ride better as well? is Rough Country a good kit? what would be a good kit for my intended purposes? here's a pic of my truck and my bug. Link to comment Share on other sites More sharing options...
dunnc1991 Posted February 21, 2015 Share Posted February 21, 2015 Rough country is hit or miss depending g on who you talk to. My dealings with them, I've never been impressed with their quality, however customer service was good. A soa swap can yield anywhere from 5" up to 6.5"+ of lift depending on condition of your springs/ spring perch height. For a DD I personally wouldn't go that high unless you want a large lift. If you wanted to go that high, I'd run control arm drop brackets since it will be used more on road then off. There are a lot of opinions on lifts, so I'm sure others will chime in. Link to comment Share on other sites More sharing options...
Lee21490 Posted February 21, 2015 Share Posted February 21, 2015 For a great deal less $$$ You can just do a control-arm drop bracket. It brings your control arms back to around stock angles, And will drive the same on the road as a longarm.Flex's pretty damn well offroad too, And you can always just upgrade to a longarm down the road if you decide to. Rough country is hit or miss depending g on who you talk to. My dealings with them, I've never been impressed with their quality, however customer service was good. A soa swap can yield anywhere from 5" up to 6.5"+ of lift depending on condition of your springs/ spring perch height. For a DD I personally wouldn't go that high unless you want a large lift. If you wanted to go that high, I'd run control arm drop brackets since it will be used more on road then off. There are a lot of opinions on lifts, so I'm sure others will chime in. Beat me to it by seconds lol Link to comment Share on other sites More sharing options...
westypoo Posted February 21, 2015 Author Share Posted February 21, 2015 well are their any long arm lift kits you guys would recommend? what hight lift would you guys recommond? i kinda want a complete kit like; lift, extended brake lines, any needed drop brackets, shocks, etc. one that takes a lot of the guess work out of it. Link to comment Share on other sites More sharing options...
Incommando Posted February 21, 2015 Share Posted February 21, 2015 4.5" front will mean the rear is about 1.5" higher then the front if you SOA the rear. You need a minimum of 5.5" in the front IMHO Link to comment Share on other sites More sharing options...
Pete M Posted February 22, 2015 Share Posted February 22, 2015 staying spring under with some 4.5" leaf packs would probably work better if you tow a lot. Link to comment Share on other sites More sharing options...
ggcnash Posted February 22, 2015 Share Posted February 22, 2015 ^this^ Link to comment Share on other sites More sharing options...
Crash Posted February 22, 2015 Share Posted February 22, 2015 It is my understanding that Rusty's has decent 4.5 lift leaf packs for MJ. Those and maybe their coils are the only things I would think about getting from there. But I do beleive that they have a kit. I definitely wouldn't run their track bar though. I've heard that Hellcreek makes a nice leaf setup. Although, I have heard conflicting things about them still being around or not. Best bet is to buy parts you want and have a BIY kit, vs Spending a large chunk of cash on a kit that may or may not have parts you want. For example, OME 934 coils, JKS or Currie ACOS, IRO trackbar/bracket, Currie steering (or maybe WJ/crossover steering swap), goferit tie rod flip insert for driver side knuckle, 24+ in stainless brakelines (pending exactly what you need), Clayton Long arm (maybe 3-link?), extended sway bar disco, for the front Hellcreek rear lift leafs, stainless extended brake line, maybe steel axle shims if required, extended shack if necessary. IF you go with bigger tires, REGEAR your axles Shocks, At a MINIMUM, Bilstein 5100s. 7100s/w/ resi are better. Link to comment Share on other sites More sharing options...
Incommando Posted February 22, 2015 Share Posted February 22, 2015 staying spring under with some 4.5" leaf packs would probably work better if you tow a lot. ^this^ ^that^ Link to comment Share on other sites More sharing options...
westypoo Posted February 22, 2015 Author Share Posted February 22, 2015 ok thanks guys. looks like i got some more reading/ research to do. all the acronyms and i only could understand like 1/2 of what some where...lol. Link to comment Share on other sites More sharing options...
Pete M Posted February 22, 2015 Share Posted February 22, 2015 well, we have this: http://comancheclub.com/topic/12163-acronyms/ but i'm guessing you're referring to the company names. most of them can be searched for by using their acronyms. :thumbsup: Link to comment Share on other sites More sharing options...
westypoo Posted February 23, 2015 Author Share Posted February 23, 2015 How's zone off-road stuff? Link to comment Share on other sites More sharing options...
Incommando Posted February 23, 2015 Share Posted February 23, 2015 How's zone off-road stuff? They are newish but have a good rep. They are a division of BDS and BDS has a very solid reputation. Link to comment Share on other sites More sharing options...
dscowell Posted February 24, 2015 Share Posted February 24, 2015 Like Incommando said Zone has a good rep and branches off BDS. I really like BDS stuff but it can get a little pricey. Link to comment Share on other sites More sharing options...
cody.quattlebaum.16 Posted February 25, 2015 Share Posted February 25, 2015 I went with a semi pieced together kit. Front end is Clayton long arm kit for the xj and for the rear I got the t&t 1" u bolt eliminator kit. Link to comment Share on other sites More sharing options...
