Transfer case electrical harness.
A couple months ago I made my 2wd to 4wd. It works fine and dandy, but I don't have the harness that goes from the transfer case to the transmission harness connector (if that's what its called). Anybody have an idea what that harness is? If you know what I'm talking about.
Thanks, Steve
The Vehicle Speed Sensor (VSS, i.e. speedometer sensor thing) comes off the tcase, although if you've got an '89 (like your username), then you have a mechanical speedometer, and all you'll have is a cable (I think. Do your own research). If you've got a tcase out of a later year, then the speedometer could be electrical and would be a harness of sorts.
My '91 has an electric speedometer, and if my memory is correct from almost a year ago when I had my trans out, there was a connector for it at the transmission dipstick. There's also a connector there for the neutral safety switch. I don't know how the harnesses and connectors would be routed on a manual, though, where there's no trans dipstick for them to attach to. I'm also pretty sure that to get it to work with a mechanical speedometer, you'd have to change the "speedometer pickup deal"/VSS for a mechanical one, and run a speedometer cable, which would be in place of the electrical harness. You'll likely be needing a longer speedo cable, but again, do your own research.
If you are just referring to the vacuum harness, as ftpiercecracker1 says, unless you feel the need for a functioning CAD (why?) then you have no need for it. It would be more work than it's worth with too many potential for leakage to get in tapped into your 2wd vacuum setup.
I'm having the same issue. There is a GM weather pack connector on the transfer case. It's a simple switch, inside the case. But I can't find the electrical connection on the harness.
No vacuum 4X4 anything on my jeep.
It's odd, cause the engine, transmission, and transfer case came out of a 91 Cherokee. I also transplanted the 91 electrical harness. But I still can't find the original connector on the harness.  I'm thinking it may have been a pig tale, that connected to another part of the harness...
They sell GM type electrical connections at some parts stores. I'll just make a new connector and run to the dash light, If I can't locate the electrical plug.
Steven and daking: We need to know both the year of your MJs and the year of the swapped-in transfer case, AND we need to know if the donor vehicle for the transfer case had a disconnect axle or not. We also need to know if the axle you installed has the front axle disconnect and, if so, if you made it operational or if you locked it in the engaged position.
My '91 MJ has a CAD. The part-time light is turned on by a switch on the axle, not the tcase. Like I said before, there is a connector for the tcase, though... all the wiring from transmission and tcase connected to the harness at the rear passenger side of the motor.
1987 Jeep MJ - Body, fuel tank, sender* (modified to work with 91 gauge), seat,
1991 Jeep XJ - 4.0 Engine, AW4, NP231, Front Axle, Rear Axle, Dash, Computer, Harness. Steering column
Front axle is NOT CAD. Transfer-case has no vacuum connections.
Is the 4X4 light controlled from the shift lever on these, or from the switch on the transfer-case?
Thanks
Thanks
My aw4/231 came from late 95 the light is controlled u switch on TC the only other connection is the vss
My MJ is an '89 but the transfer case, I'm not sure of, my brother in laws dad worked for Jeep for over 35 years and has collected parts, jeeps etc. So I just grabbed a trans and t case and put it in. I think it's an 89 though, the front axle i know is an 89.
