marvel mystery oil?
You'll probably get a lot of different responses,
but I like and use MMO when needed.
I've used it in my fuel system as a fuel additive, and as air tool lubricant more than I've used it in the engine oil, but I don't think you have to worry about it hurting your your engine.
I usually use a quart or so of transmission fluid when I have a lifter tap, but I could see using MMO instead.
Good luck.
Haha no need to feel like a smartass would be the best opportunity to anyways. Just wondering not always the best to do as label says so was curious if this was on of those. Thank you for the responses everyone
I like MMO, but would NOT ise it as a lubricant for air tools. It has micro abrasives in it that may affect the tools. With that said, if I've used it on gunked up, noisy engines with good results; going so far as to use it to unstick the compression rings on an old ait cooled VW that had no compression. Ran fine afterwards.
Randy has a point.
Use a Wix or Napa filter. Change oil. I love Rotella T3. Use a quart of MMO with it and do a change after 1500 miles or so.
When you start up and have the lifter tick, shut the engine off for half a minute and then restart. Is the tick gone?
Randy has a point.
High quality oil and filters are essential, like Cruiser says. I run Wix filters and use 5-40 Mobil 1 Turbo Diesel oil in my Jeeps.
Randy has a point.
I'm running a napa filter and valvoline 10-30w just did a oil change about 150 miles ago when i put the engine in. Engine only has 96k miles on it. I think ill do another oil change and run Rotella t3 and a qt of MMO. Do you recommend Wix or Napa filters? Also yes if i shut it off wait and start again it'll still have it.
 Thank you everyone for your responses!!
Napa is made by Wix.
Napa has them as Silver, Gold, and Platinum.
They're designed for different oil change intervals.
Silver-about every 3000 miles
Gold-7500 miles
Platinum-Synthetic oil and extended intervals
You can buy the Silver ones really cheap!!
