1990 short bed resto; TDi, 3-link, coilovers, doubler, JK axles
This isn't really a build thread so much as a journal.  I posted up as many of the old pictures I've got from over the years.  Its been a great little truck and has many memories attached to it.
TDi swap, frame stiffening stuff begins on page 5, three-link stuff begins on page 6.
Keep in mind that I am updating this thread as I progress.
Got her in October of '07 from another CC member: KYMJ
A nice, rust-free, 4x4 MJ with all the right stuff for a good price.  Had to jump on it!
  • Replies 268
Posted Images
Ye olde original engine was on it's last legs so I picked up a ~50k H.O. engine from a '95 XJ.  I changed every gasket on it before swapping it.
Before:
Donor:
After!  I ended up modifying the Renix intake to work with the H.O. head and exhaust manifold.  All it took was an EGR delete plate and welded-shut tube, some minor grinding at the corners of the intake, and a trimmed gasket.
Looks good. I love this spinnaker blue. Just wondering what size front spacer you are using? I was wanted to put some in to level the front out since I already have the Chevy shackles installed and to fit a larger tire than the 205/75.
The blue (spinnaker blue or pacific blue??) never really has been my favorite, but it definitely has lots of memories attached to it.  I may end up keeping the color when I get the body fixed up.  Heck I might even put the stripes back on it who knows.
I believe it was a 3/4" spacer puck.  I'll be getting rid of them soon if you're interested  :D
Time for some upkeep and a few mods.
1/2 ton Chevy hoses (NAPA 38183 and 38182.)  Had to modify the bracket, and I'm not so sure they're not going to contact the wheels; we'll see.
JKS ACOS spacers; likely going to push the lift a little too high even all the way closed. Probably going to shim the lower control arms out as far as they'll go. At least she'll sit level again!
You can dive into projects like this knowing that there's going to be something else that needs to be changed/fixed/modified while you're there... like clockwork!
Bent LCA bracket; apparently this is a common problem on all linked Jeeps.  Now the whole thing gets to come out.
  • A-man930 changed the title to 1990 short bed resto; TDi, 3-link, coilovers, doubler, JK axles
