thejim42 Posted September 25, 2014 Share Posted September 25, 2014 Well after a year the replacement knob i bought for my jeep bit the dust and now its annoying as hell. also need to change the boot. I bought a leather one at walmart for $8.00 but it doesnt look right in my truck so id like to find an OEM boot. But id like to go with a different Jeep knob because i don't really find the factory style comfortable. I found a knob off a 97+ cherokee and a cj/yj type. will they both fit and does anyone have any input on comfort? Link to comment Share on other sites More sharing options...
87Warrior Posted September 25, 2014 Share Posted September 25, 2014 I just installed a Rampage shift knob on my AX5 with the 10mm threads. Nice simple solid aluminium knob that can't fail like the factory piece. Link to comment Share on other sites More sharing options...
Eagle Posted September 25, 2014 Share Posted September 25, 2014 On 9/25/2014 at 2:48 AM, thejim42 said: I found a knob off a 97+ cherokee and a cj/yj type. will they both fit and does anyone have any input on comfort? The one for the 97+ Cherokee also fits the TJ Wrangler. I have it in my 2000 XJ 5-speed, and I retrofitted my '88 MJ after failing to glue the factory knob together with epoxy. I like the new style much better than the early style, for comfort of operation as well as for longevity. Link to comment Share on other sites More sharing options...
thejim42 Posted September 25, 2014 Author Share Posted September 25, 2014 Does it just spin on? How exactly did you retrofit it? Link to comment Share on other sites More sharing options...
Rockfrog Posted September 25, 2014 Share Posted September 25, 2014 I just made my own for my 88, a 10mm all thread connector, a drill, and a knob of my choosing, all a little 'no more nails' construction adhesive amd she's been good for over a year now. The only picture I can find of mine. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 25, 2014 Share Posted September 25, 2014 http://www.ebay.com/itm/NOS-Jeep-Gear-Shift-Boot-XJ-Cherokee-MJ-Comanche-CJ-7-8-Scrambler-YJ-Wrangler-/231329782891?pt=Vintage_Car_Truck_Parts_Accessories&hash=item35dc545c6b&vxp=mtr Link to comment Share on other sites More sharing options...
Eagle Posted September 25, 2014 Share Posted September 25, 2014 On 9/25/2014 at 4:37 AM, thejim42 said: Does it just spin on? How exactly did you retrofit it? Take off the old, put on the new. Yes, it just spins on. The knob itself has an inside thread. There is a recess under the shift pattern medallion for the lock nut. In fact, on the '88 MJ I never got around to installing the medallion -- I left it off because I knew I'd be working on the truck and I didn't want to gouge the new knob prying the medallion off -- and now I have no idea where I put it for "safekeeping." Link to comment Share on other sites More sharing options...
Dadinator Posted September 25, 2014 Share Posted September 25, 2014 I found an aftermarket 8 ball one at the jy in a mj they had. It was in perfect shape. They gave it to me because I was buying Dakota seats at the time. I love it. Link to comment Share on other sites More sharing options...
TheDude Posted September 25, 2014 Share Posted September 25, 2014 You can one with custom engraving here: Azzysdesignworks.com Link to comment Share on other sites More sharing options...
thejim42 Posted September 25, 2014 Author Share Posted September 25, 2014 I thought about that. But I can get an OEM one for about 1/4 of the price Link to comment Share on other sites More sharing options...
Keyav8r Posted September 26, 2014 Share Posted September 26, 2014 I had an 88 Pioneer and I have a 91Eliminator and I bought replacement OEM style knobs for both because I wanted to keep the original look and I like the feel of the knob. Both were/are secured on the shaft by a locknut on the threads below the knob. It's a round nut with two flats for a wrench. If I remember correctly, the threads are different between the two models. Link to comment Share on other sites More sharing options...
Eagle Posted September 26, 2014 Share Posted September 26, 2014 On 9/26/2014 at 12:40 AM, Keyav8r said: If I remember correctly, the threads are different between the two models. No, they aren't different. I have the new style knob in my '88 MJ. Same thread -- no adapters. Link to comment Share on other sites More sharing options...
Blue XJ Posted September 26, 2014 Share Posted September 26, 2014 I think in 95 or 96 the AX15 trans switched to a Metric thread, I know the one in my Jeep is from a 99 and it is an M10 thread. The MJ era AX's should be a 3/8" thread. Link to comment Share on other sites More sharing options...
Keyav8r Posted September 27, 2014 Share Posted September 27, 2014 Eagle and Blue XJ - you're right about the threads. Thinking back, I pulled a knob off a later model XJ at the JY and it had the different thread. Thejim42 - if you're looking for the boot that fits on the console, they're available on eBay and Amazon as well as other places. If you want the boot that mounts on the floor/transmission hump, the OEM part I bought for my 88 is PN 53002864. Bought one a little over a year ago from the dealer for around $35.00. Some members have used the Quadratec PN 52106.03 and said that it was a good fit. I believe it costs a good bit less than the OEM part. Link to comment Share on other sites More sharing options...
