Blower For Heat. And Signal Lights Not Working
Hey guys,
The other day on my way home from work I noticed that the blower was not blowing any heat out. Then when I turned off the main road I noticed that my signal lights were not working. No flash in the cab, nor do the outside lights work. I have head lights, tail lights, dummy gauges work when turning the key. I checked the fuses inside the cab and they all look good. I looked at cruisers ground tips on the link in his signature but didn't see much about either of my problems. Any help would be greatly appreciated.
Just a silly question regarding the blower: had you taken out your radio recently?  If so, check it to make sure you did not push the power supply connector off.  You may have slid it back a little so is was still contacting at first but the shaking of the truck knocked it off.
Voice of experiance :oops:
