jimoshel Posted December 20, 2013 Share Posted December 20, 2013 Got a '90 MJ up on blocks i'm doing a 4WD swap on. 4.0, AX15, 3.07 D35. The donor for the axles is a '96 XJ 2.5, AX4, 231, 4.10 D30, D35. I'm keeping the 4.0, using a AX15, 231 combo from a 3rd vehicle and using the two 4.10 axles. My question is, is it easier to modify the XJ D35 to fit the MJ? Or would it be easier, better, to keep the MJ D35 and swap the gears? I've swapped gears before but never swapped or modded a rear axle. :dunno: Link to comment Share on other sites More sharing options...
MrSimon Posted December 20, 2013 Share Posted December 20, 2013 Generally its good to leave gears in their original housing. They can certianly be swapped into a new diff, but there is a chance they won't mesh together the same way, possibly causing noise, vibrations, or other more serious issues. Preparing an XJ axle to go under an MJ is relatively easy, but does require grinding and welding. Edit: I'm sure you've heard this before .... but if you are going to all this trouble, it would be ideal to use a stronger axle than a D35. I'm assuming you are sticking with the D35 because you have 4.10s in it (them), and that makes sense. Its just a shame for you to do all this work and still have a D35. Link to comment Share on other sites More sharing options...
yxmj Posted December 20, 2013 Share Posted December 20, 2013 6 of this= a half dozen of that The newer axle will have the larger axle shafts and slightly bigger bearings.....but you will have to change the spring perch location (assuming you are keeping the SUA configuration) If you are familiar with it a gear swap is fairly straight forward.....especially if the diff is out of the truck and easy to work on.... :wrench: Link to comment Share on other sites More sharing options...
jimoshel Posted December 20, 2013 Author Share Posted December 20, 2013 I was leaning to the gear swap but wanted to hear from someone who's been there. WANTED TO SWAP; 1 D35 with 4.10 gears straight across for 1 D44 or 8.8 with 4.10'S likes to dream. Link to comment Share on other sites More sharing options...
carnuck Posted December 20, 2013 Share Posted December 20, 2013 I hear that! I have a matching pair of 3.73s (D30 vacuum front and D35 rear that is SOA correctly except the shock mounts, but they work) that I'll be swapping out when I'm feeling better for non-vac 4.10 front and 8.8 or 8.25 with 4.10 rear. Then my axles will be for sale. Link to comment Share on other sites More sharing options...
Eagle Posted December 20, 2013 Share Posted December 20, 2013 If you can weld (or know someone who can) IMHO it's far easier to just move the spring perches on the XJ axle to the MJ locations. Link to comment Share on other sites More sharing options...
Bornindesert Posted December 20, 2013 Share Posted December 20, 2013 The D35 in my White Comanche...came from an XJ during the 2X to 4X conversion. Perches cut off with a torch, relocated to the MJ locations, welded up. Done. If you go the gear swap direction, would run the Dana serial numbers through the Dana Axle Identification website and make sure they are both either non C-clip or C-Clip as I think the carriers and housings do not interchange. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 21, 2013 Share Posted December 21, 2013 2 hours work and you can have the D35 set up...................then look for a replacement. BTW.......with all the 'fear' going round about the D35........I carry and pull a lot of weight and mine hangs in there just fine. But I'm also looking for a replacement, I'd like to have the AMC20 with 4.11s. I want one of the Aussie lockers for the rear, I'm just not willing to put $300 and another $65 into a cover for the D35. Link to comment Share on other sites More sharing options...
jimoshel Posted December 21, 2013 Author Share Posted December 21, 2013 OK.. I'm convinced. It's axle mod. Tnx for the input guys. Link to comment Share on other sites More sharing options...
carnuck Posted December 21, 2013 Share Posted December 21, 2013 I've carried 3,000lbs and towed FSJs with my D35. Shows no signs of going south (running synthetic oil to protect the pinion bearings mind you) Link to comment Share on other sites More sharing options...
