89JeepMJ Posted November 21, 2013 Share Posted November 21, 2013 I have a D30 and D35 under her right now, with 3.55s. I'm going 33" tires up from my 31". i got a F150 8.8 sitting on the bench in the shop. i know their a little to wide for the MJ. I'm thinking regearing the front D30 and swap the out the D35. how low can i go with the D30, will i need a carrier. if i get a 8.8 out of an explorer how low can i go? same with D44 or 8.25. this is something i really don't have any know how in. i need options and ideas thanks guys Link to comment Share on other sites More sharing options...
Mattwheels Posted November 21, 2013 Share Posted November 21, 2013 I think the D30 max gears are 4.88 Link to comment Share on other sites More sharing options...
Stacks Posted November 21, 2013 Share Posted November 21, 2013 Here is a link that will answer your questions on gears and where the carrier break is. Hope this helps. http://www.differentials.com/wp-content/uploads/2011/09/2012-WCD-Catalog.pdf Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 21, 2013 Author Share Posted November 21, 2013 so a 8.8 doesnt need a carrier because there is no breaks but i D30 and D44 need a new carrier to go 4.10/4.56 because it has 3.55s and its on the other side, right? Link to comment Share on other sites More sharing options...
zackcj7 Posted November 21, 2013 Share Posted November 21, 2013 so a 8.8 doesnt need a carrier because there is no breaks but i D30 and D44 need a new carrier to go 4.10/4.56 because it has 3.55s and its on the other side, right? Yes, that is correct. I do have an 8.8 already setup with 4:56 gears for sale BTW. Little far of a drive for you though. :brows: Link to comment Share on other sites More sharing options...
mvusse Posted November 21, 2013 Share Posted November 21, 2013 Spicer only made gears down to 4.56 for the Dana 30. There are aftermarket 4.88 gears available, but the pinion gear is so freakishly small there isn't w whole lot of engagement between the gears making it very weak. I suggest going no lower than 4.56 on a Dana 30. Ford 8.8 (all variants) can go down to 5.71 Dana 44 can go down to 5.89 (standard cut/low pinion) or 5.38 (reverse cut/high pinion, front axle only) Chrysler 8.25 can go down to 4.56 There is no reason the 8.25 shouldn't be able to go lower other than nobody makes lower gear sets for it. Link to comment Share on other sites More sharing options...
Timeless Posted November 21, 2013 Share Posted November 21, 2013 Don't go lower than 4.56 with the dana 30 for the reasons mvusse states above. 4.56:1 is just fine for 33's or 35's. Your F150 width axle is significantly wider, about 5", than a stock dana 30. Unless you're going to a similar or same width axle upfront, you'll probably be better off tracking down an explorer width axle. Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 21, 2013 Author Share Posted November 21, 2013 Spicer only made gears down to 4.56 for the Dana 30. I know zackcj7 already answer it but just to double check. for the D44 and D30. i need a carrier though to go that low right? Link to comment Share on other sites More sharing options...
mvusse Posted November 21, 2013 Share Posted November 21, 2013 The carrier break for a D30 is 3.55 and down, 3.73 and up. For a D44 it is 3.73 and down, 3.92 and up. So if you currently have 3.55 gears, you will need a different carrier for your Dana 30. For the Dana 44 it all depends on what gears the axle has when you get it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 21, 2013 Share Posted November 21, 2013 You also have the option on the D44 if it's 3.55 or below to use 4.10 and up "thick" gears and retain the lower numerical carrier. Link to comment Share on other sites More sharing options...
Pete M Posted November 22, 2013 Share Posted November 22, 2013 or you can ignore all of that and just find a dana 30 and an explorer 8.8 or XJ 8.25 with 4.10 gears already in them and run it that way. :thumbsup: Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 22, 2013 Author Share Posted November 22, 2013 all valuable points ha. looks like i gotta do some searching Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 22, 2013 Author Share Posted November 22, 2013 Ford 9 inch not an option? Link to comment Share on other sites More sharing options...
Pete M Posted November 23, 2013 Share Posted November 23, 2013 9" from a truck is wider than our stock axles. Link to comment Share on other sites More sharing options...
jpnjim Posted November 23, 2013 Share Posted November 23, 2013 Lincoln Versilles [sp?] 9" rears were 58-60" wide (I forget now) 5on4.5" wheel pattern, and the hot ticket back in the day, tough to find now though. Mustangs from 68 or so, till the Mustang II came out are also a good MJ width if you can find one. Granadas also got some 9's but I'd guess the junkyard supply of them is long gone as well. Link to comment Share on other sites More sharing options...
jpnjim Posted November 23, 2013 Share Posted November 23, 2013 For truck 9's only the 66-77 Broncos are close in width, something like 57-58" wide, but are the bigger 5 on 5.5" wheel pattern Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 24, 2013 Author Share Posted November 24, 2013 I emailed a guy about a ford 9 inch. ill see what specs he gets back to me with. Link to comment Share on other sites More sharing options...
