Comanche With A 401 In It.
carnuck
This is an actual MJ with a 401 in it. A professionally built one at that... Making 517 dyno confirmed HP on pump gas.
He said it does a 12.1 in the quarter too, when it hooks up and finally gets traction that is.
Rob
12.1 in a truck that light is way too slow for 517 HP. If optimized that claimed combo should be running high 10's when it hooks up. That ET indicates closer to 390-400 hp. Still not bad but just a reminder that "confirmed" may not mean "real."
Rob
NHRA rules say a roll cage is needed if running 11.49 with a hard top and 13.49 in a convertible. I don't see a roll cage so maybe running 12's for that reason. Some tracks will flag your car if you run faster than your safety equipment allows.
