Zj Springs
Has anyone on the board here done the swap? I'm looking into doing it shortly and a search to find some information came up dry.  What can you guys tell me if you've done it. When I grab the springs what else should I make sure to get? Will my shocks still work or should I get extended ones? Thanks guys.
You need the aftermarket 2" drop shackles for a Chevy.
Be aware that this will change your pinion angle and thus might cause a driveline vibration; an add-a-leaf would be a better solution. Best would be a 3" lift pack from Hell Creek. Also since our trucks have a pretty good rake from the factory, it might look fine lifting just the front and leaving the back alone.
X2
look at my avitar pic....lifting the front made it look level
Been searching for springs online. Looking at the Moog CC782 springs on Amazon. They're variable rate springs listed as a direct replacement. Anyone have experience with these?
There was someone in NAXJA-NAC several years ago who was running those and he liked them very much. But I don't recall if they generated any lift. Mostly, they are designed to increase capacity without making the ride stiffer.
