What Brand Of Lift Is This?
Looks like a garbage home brew 3 link.
Pass.
Rob
Yep.
I've seen several examples of Clayton's long arm kit. Compared to what a pro does, the long arms in that setup look absolutely frightening.
And XJ rear springs won't be of any use in an MJ.
If you could get it for under $100 you might be able to use some of the pieces if you have the ability to piece the rest together anyway. As mentioned the rear springs and shocks are worthless for an MJ. Revolver type shackles have many more critics than supporters from what I have read. You are getting a used track bar, used front springs, and used shocks all of which are of unknown make and some brands are downright junk even new. The rest is scrap IMHO.
