Air/train Horns
Yes, I did in fact spend that much on a horn and air compressor kit.  Was it the smartest use of money on the Jeep?  No.  Was it worth it in the long run?  IMO, yes.  I was 17 and my paychecks didn't have to be spent on anything essential, so I just bought stupid crap.
If eBay would let me go back that far in my purchase history, I'd be glad to show y'all.  I have can post pictures of my setup and of the box it originally came in. :thumbsup:
As long as it was worth it to you, in the long run, that's all that matters. How old are you now?
I'm 25 now.  In hind sight, I should have been a little more savvy with my money back then.  I certainly wouldn't go and spend that much on a horn now lol.
No sweat. All of us have made expensive impulse purchases we may have regretted later. And you really never outgrow it.  :yes:
yup, I too remember having more money than brains back in the day (*cough* dual sunroofs *cough*). :yes:
Damn straight!  I bought a 25 year old Jeep pickup for $400, then turned around and spent 3K+ plus on it...that's why I'm broke now.... :doh:
I love the cannon idea too...or faux missles on a rotating faux launcher.  :yes:
I don't have or need a horn. I mounted a 155mm cannon and turret from a surplus army tank on my MJ. Needed spring boosters and heavy duty shocks
. Somebody gets in my way, or just annoys me, I swing the turret around and point the barrel at them. Gets better results than any horn ever did.
This really wouldnt suprise me. Or even jim having a 155mm cannon sitting in a barn somewhere.
On this subject, i have seen a setup where a guy rigged up a semi-auto 12ga shotgun under his hood. removed the stock, extended mag, yadda yadda. Used a trunk latch solenoid to work the trigger. Obviously not legal, and i in no way accept any responsibility for anyone dumb enough to attempt to set this up on their vehicle. Still...rather genius i must say.
That's called a southern security system hahaha.
Close....more for road range when the darn prius won't get outta the way.
THIS is a redneck security system
No it's not air horn loud but it's much louder than stock. 130 something decibels I believe, loud enough to get the attention of any driver even with windows rolled up and music blasting (In my experience anyway). Gotta be a pair though (hi + lo tone). I recommend them as a much more simple replacement than air horns with all their compressors and relays and pipes. Worth noting that you cannot tell properly by listening to a video that has automatic electronic noise leveling. You can hear the tone but not the volume.
If you get a Wolo 419 Bad Boy horn or the knock-off above, it will not be as loud as a real air-horn, but for a jeep definitly Much louder
Or they now show a Big Bad Max at 123dB. Cost wise these are a cheapish easy addition, one horn, one relay, & wire.
 if twined in with the existing or upgraded horns. On my Dodge I have all on the same button, two factory horns, a low Bull Horn,
http://www.farmandfleet.com/products/392585-wolo-bull-horn.html
and the twin bad boy horn.  Almost loud enough over the Cummins 12Valve roar...
One of the electric PA style horn units might be a option too.  The horn sound I really want is the Fire Truck / Ambulance electronic low honk, simulating a old air horn.
that's the sound i want but the sound of a semi will have to do since the old air horn sound from a firetruck is too hard to find in my area,
Redwolf
