jimoshel Posted September 10, 2013 Share Posted September 10, 2013 Got a '97 Grand Cherokee with the 4.0 engine and a bad 42RE. Got perfectly good '93 AW4 laying on the ground I'm going to swap into it. Anybody already done this? Got any hints or things to look out for? Tried search. No luck.? Link to comment Share on other sites More sharing options...
Eagle Posted September 10, 2013 Share Posted September 10, 2013 If I remember correctly, the '93 ZJ came with the AW4. (However, my memory ain't what it used ta was.) Basic considerations I expect you're already aware of: you'll need the TCU for the AW4, and I assume it may require an AW4-specific TPS to send the correct signals to the TCU. Link to comment Share on other sites More sharing options...
jimoshel Posted September 12, 2013 Author Share Posted September 12, 2013 Tnx Eagle. Game has changed. Just found a 42RLE from a 2004 Wrangler. Will IT fit? This is a really nice '97 Grand Cher. I would really like to get it running . Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 12, 2013 Share Posted September 12, 2013 That would be the best swap Jim. The 97 harness has no wiring provisions for an AW4 TCU. And since it's an OBD2 system, swapping in the 93 ZJ OBD1 harness would be a PITA. As far as the 42RLE interchanging with the bad 42RE, I have no idea. This link may have some info on the tranny swap. If it does not, it's interesting reading anyhow: http://www.jeeps-offroad.com/showthread.php?t=4740 Link to comment Share on other sites More sharing options...
carnuck Posted September 12, 2013 Share Posted September 12, 2013 I'd do the AW4 in a heartbeat. Switch the JGC's TCU box for one from a stick (if separate still) and wire the AW4 in. The HO TPS for an XJ should fit and the trans controller spliced in pretty easy. If I liked JGCs, I'd do it. Link to comment Share on other sites More sharing options...
jimoshel Posted September 13, 2013 Author Share Posted September 13, 2013 I've got a '93 XJ with a bad 4.0 and a good AW4. If I understand you correctly I have everything there that I need for the swap? And as long as we're on the subject, kind of. What's the difference between a 42RE from a '97ZJ and a 42RLE from a '03 Wrangler? Link to comment Share on other sites More sharing options...
jimoshel Posted September 13, 2013 Author Share Posted September 13, 2013 Could not get it to copy and paste but I found a great write up on the 42RE to AW4 swap on Steve Olson's Jeep site. Pretty well covers everything. http://www.stu-offroad.com/engine/aw-4b/aw-4b-2.htm Link to comment Share on other sites More sharing options...
jimoshel Posted September 13, 2013 Author Share Posted September 13, 2013 This is not my write up. I copied it from Jeep Forum. Okay, so you want to install an Aisin-Warner AW4 transmission into your OBDII ZJ, but have no idea about how to do it? The following is my writeup of the part list including the part numbers where needed as well as step by step installation steps. (Part numbers from dealership surrounded by asterisk's)Parts list:1X AW4 (Must be a 23 spline, found in 91 and up XJ's behind the 4.0, as well as select ZJ's in early 93)1X Torque converter from an aw41X Flex plate from an aw41X Dustshield from an aw4 *53005907 AND 53004908*1X TCM from same year XJ3X connectors for TCM (there are two - one gray and one black - that connect to the body of the transmission and one that connects to the TCM)4X Torque converter bolts (flex plate bolts are the same for both setups) *34202497*1X AW4 shifter cable bracket *53007746*1X AW4 Shifter cable *5207 8452*1X AW4 Shifter bezel *550336461X Aw4 floor shifter for a 93 ZJ with the AW4 *53007749*1X Tcase shifter bracket on the Transmission body *52077509* (I ended up not using this, I went with a Novak shifter kit for the 231 instead.1X Cross member from a 93-95 ZJ (be sure to get the bolt that holds the mount onto it)1X Cross member trans mount *52018857* (I bought from Advanced Auto PN - 621049)1X Crank Position sensor (This one is tricky, you need to buy one out of an XJ, but you need to buy one out of the same year vehichle that you have. I have a 96, so I bought one from a 96 XJ with an Advance Auto part number of AL2017. This is due to the connectors, for some reason they changed them from year to year, but kept them the same across the board for the ZJ and XJ at least in 1996)Assorted fittings for the cooler lines - I used the stock lines that came with the AW4 and spliced in soft linesI installed an auxillary cooler in line after the stock cooler on the radiator - This isn't necessary but heat is the easiest way to kill a transmissionDriveshafts - I am using a driveshaft that is off a zj with the 42re and the 242. I tried to use a front driveshaft of a zj with the 42re and the 242, and it was too long; even after compressing it all the way, it couldn't even fit between the yokes. Another edit - The front driveshaft from an XJ with the aw4 and 4.0 WILL NOT fit, it only allows less than half an inch of travel, which isn't near enough.Parts to reuse from your 42RE:Flex plate bolts and spacerStarterSome bellhousing bolts, but you're going to have to buy some shorter bolts or get the ones off the aw4 equipped vehicle.Crossmember bolts to "frame" railsProcedure:Removing the 42re-This is a pretty straight forward process, so I'm not going to go into detail. I had no idea what I was doing and I still was able to do it really easily. A couple basic steps though, drop the back end of the transmission then remove all the connections off the transmission. Then unbolt the bellhousing including the starter and all of the bolts holding on the dust shield. You should be able to then rotate the flex plate to remove the 4 torque converter bolts. If everything is out, you should be able to rock the transmission off the back of the block, but be careful it falls off a jack easily.Installing the aw4-Everything should be out of the way and ready to install now. This image has been resized. Click this bar to view the full image. -Place the top portion of the dust shield on the back of the block. It aligns itself on pegs on either side of the block. Then install the flexplate and torque to spec. You're going to have to spin the flex plate around to line it up correctly because the bolt holes aren't concentric on the crank. Don't forget to install the spacer on the transmission side of the flex plate. This image has been resized. Click this bar to view the full image. -Install the torque converter onto the input shaft of the transmission. Be sure to rotate it at least 90 degrees off vertical in both directions while pushing aftward. This is to ensure that the converter seats on both sets of splines on the input shaft.-At this point, you're really ready to put the transmission onto the back of the block. Get it under the jeep and jack it up high enough, then using the aforementioned pegs on the back of the block, line up the transmission and bolt it on. Be careful with this step. You shouldn't force it to mate up with the back of the block. If it is done correctly, it will easily go in. One tip about the torque converter bolts - install one but don't tighten it much. Then rotate the flex plate enough to get the opposite bolt in, then just work your way around to all the bolts, tightening them in increments. I tightened the first bolt too much and I couldn't spin the flex plate at all because the input shaft was at an awkward angle I guess. (SIDE NOTE - You can see where the bracket for the shifter cable goes in the following picture, it is just to the left of the center of the picture where there are two shiny spots with bolts in the middle of them on the backside of the bellhousing) This image has been resized. Click this bar to view the full image. -Bolt the lower portion of the dust shield onto the bellhousing. Take care of little things at this point such as reinstall the starter onto the tranny. Also run the lines. I cut the stock lines for the AW4 and then used a flaring tool in order to run soft line. I used fuel pressure line.-Using the pre-95 crossmember and the 93 ZJ mount, mount the rear of the transmission. Reinstall the Tcase. This image has been resized. Click this bar to view the full image. This image has been resized. Click this bar to view the full image. -Now for the interior and the shifter linkages. For the floor shifter, you have to use the one that shifts the aw4 because the gears are in different positions versus the 42re. You also have to use the aw4 shifter cable that goes between the gear selector and the gear selector on the body of the transmission. It may not make sense as to why you have to do this, but it's because the cable that actually moves within the shielding is a slightly different length. This picture shows the interior completely torn apart. This was because in order to install the 4wd linkages (I did this transmission swap to convert my ZJ into 4wd) I had to replace the pan that the gear selectors bolt to in order to mount the 231 handle. You won't have to remove the carpet to just replace the shifter and it's cable, but it would make it easier for the cable portion. I replaced the cable after I had already put the carpet back, so I ended up just cutting the carpet right along the shifter cable (~4" of carpet) and it made it very easy to R&R the cable. To remove the shifter handle you have to just pull really hard on it, but be careful when doing so (look at the last picture in the next set). This image has been resized. Click this bar to view the full image. This image has been resized. Click this bar to view the full image. Link to comment Share on other sites More sharing options...
jimoshel Posted September 13, 2013 Author Share Posted September 13, 2013 I just checked my parts pile. Seems I have a good AW4and a 231 removed from a '98XJ a couple months ago. Guess I'll be starting this tomorrow morn. Link to comment Share on other sites More sharing options...
Eagle Posted September 14, 2013 Share Posted September 14, 2013 Switch the JGC's TCU box for one from a stick ... Doesn't exist. The ZJ Grand Cherokee was offered with a 5-speed only in 1993, and only behind the 4.0L engine. Link to comment Share on other sites More sharing options...
carnuck Posted September 17, 2013 Share Posted September 17, 2013 Actually, you can have the JGC box converted for stick Link to comment Share on other sites More sharing options...
omega_rugal Posted March 27, 2017 Share Posted March 27, 2017 bringing this thread back from the grave guess what? i came across a crashed 93 XJ with the AW intact (except for the TCU) so i for sale cheap, since my recently acquired 95 ZJ has the bad rep 42RE i`m considering a swap when the 42RE dies. the ecu is not a problem i plan to make a shifter for it and both engines are HOs so the swap must be staright forward, both a 2WD must question is about the crossmember and trans mounts, which ones will bolt up? 1995 ZJ HO engine 1993 XJ AW4 ? trans mount ? ? crossmember ? or is there some major mod i must do? Link to comment Share on other sites More sharing options...
Hayden stepp Posted May 4, 2021 Share Posted May 4, 2021 I have a 97 jeep Cherokee xj with the aw-4 and 4.0. I was curious on if I could swap it out with the 42re transmission? thank you Link to comment Share on other sites More sharing options...
Smokeyyank Posted May 4, 2021 Share Posted May 4, 2021 26 minutes ago, Hayden stepp said: I have a 97 jeep Cherokee xj with the aw-4 and 4.0. I was curious on if I could swap it out with the 42re transmission? thank you Why do you want to put that boat anchor in? Link to comment Share on other sites More sharing options...
derf Posted May 4, 2021 Share Posted May 4, 2021 With enough fabrication and money you can do anything. But why downgrade what you already have? If the AW4 is bad, get it rebuilt. That will cost less money, take less time, and be better than the 42re or 42rle. Link to comment Share on other sites More sharing options...
