redwolf624 Posted September 4, 2013 Share Posted September 4, 2013 ok, this has been slightly botherin me and i've been puttin this project off for a long time, since march actually, when i press the parkin break pedal all the way to the floor is clicks back up untill it's a little higher than the clutch pedal, i've seen other comanches that'll have em all the way to the floor, is there a way to adjust em, is the break cable too short? what could be causin this? when i set that break pedal it doesn't roll but if i slam my door hard it'll pop off :doh: any ideas? Redwolf Link to comment Share on other sites More sharing options...
Alexia Posted September 4, 2013 Share Posted September 4, 2013 It usually means the teeth are stripped on the mechanism. Get under there with a flash light to look at it. Link to comment Share on other sites More sharing options...
Eagle Posted September 4, 2013 Share Posted September 4, 2013 Or it could mean that the mechanism needs to be cleaned and lubricated. Link to comment Share on other sites More sharing options...
redwolf624 Posted September 4, 2013 Author Share Posted September 4, 2013 It usually means the teeth are stripped on the mechanism. Get under there with a flash light to look at it. if they're stripped i'm lookin for more of a rounded tooth right? Or it could mean that the mechanism needs to be cleaned and lubricated. i'm hopin that's all it is, but yet again, i got a rusty one in my room just incase that one's trash and it goes all the way down, Redwolf Link to comment Share on other sites More sharing options...
nitroxsteve Posted September 4, 2013 Share Posted September 4, 2013 It usually means the teeth are stripped on the mechanism. Get under there with a flash light to look at it.if they're stripped i'm lookin for more of a rounded tooth right? Or it could mean that the mechanism needs to be cleaned and lubricated.i'm hopin that's all it is, but yet again, i got a rusty one in my room just incase that one's trash and it goes all the way down, Redwolf If the teeth are stripped you will have a few good teeth on each end to look at for comparison. The teeth should look the same all the way across. It may be gummed up but this is a common problem to strip out. I think jeep had a recall or service information on this back in the day. Link to comment Share on other sites More sharing options...
redwolf624 Posted September 4, 2013 Author Share Posted September 4, 2013 It usually means the teeth are stripped on the mechanism. Get under there with a flash light to look at it.if they're stripped i'm lookin for more of a rounded tooth right? Or it could mean that the mechanism needs to be cleaned and lubricated.ockquote>i'm hopin that's all it is, but yet again, i got a rusty one in my room just incase that one's trash and it goes all the way down, Redwolf If the teeth are stripped you will have a few good teeth on each end to look at for comparison. The teeth should look the same all the way across. It may be gummed up but this is a common problem to strip out. I think jeep had a recall or service information on this back in the day. back in the day, which means, now a days folks are SOL or on there own, but i'll look for any wear or crud that shouldn't be there, Redwolf Link to comment Share on other sites More sharing options...
cruiser54 Posted September 4, 2013 Share Posted September 4, 2013 ftpiercecracker did an excellent write-up on the fix. Link to comment Share on other sites More sharing options...
redwolf624 Posted September 5, 2013 Author Share Posted September 5, 2013 ftpiercecracker did an excellent write-up on the fix. got a link? Redwolf Link to comment Share on other sites More sharing options...
cruiser54 Posted September 5, 2013 Share Posted September 5, 2013 ftpiercecracker did an excellent write-up on the fix. got a link? Redwolf Can't find it now. I looked for it before I posted his name up. I think it's ftpiercecracker1. Search him. Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2013 Share Posted September 5, 2013 The teeth were fubar'd on my 92. Cleaning it did nothing for me. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted September 5, 2013 Share Posted September 5, 2013 http://comancheclub.com/topic/34536-diy-e-brake-fix/ Link to comment Share on other sites More sharing options...
redwolf624 Posted September 5, 2013 Author Share Posted September 5, 2013 The teeth were fubar'd on my 92. Cleaning it did nothing for me. noted http://comancheclub.com/topic/34536-diy-e-brake-fix/ thanks for the link, saved me from searchin today :banana: skimmed through it, and looks like a nice fix :) Redwolf Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted September 6, 2013 Share Posted September 6, 2013 Resharpen the teeth on the rotating assembly using a cutting blade and a grinder. Also weld on a new "tip" for the locking mechanism. Grind down to fit. I still have not perfected mine, but thats only because i am to lazy/busy to tear that whole mess out and fix what needs fixin. But, the rebuild platform is sound and can be made even better than factory with a little fine tuning. Link to comment Share on other sites More sharing options...
