dirty88comanche Posted March 29, 2007 Share Posted March 29, 2007 how or where can i tell what axle i have? i don't have matching hand book for the year and a few people have told me different axles. if i can slide under and check that'd be pretty great. thanks everyone Link to comment Share on other sites More sharing options...
jage Posted March 29, 2007 Share Posted March 29, 2007 look at the pumpkin shape.... you can google D44 and D30 to see exactly what they look like, choose "images" after googling... (edited) Front Rear Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 29, 2007 Share Posted March 29, 2007 SOMEWHERE on here is a similar picture...except that it includes ALL of the axle types. a little help Pete? Link to comment Share on other sites More sharing options...
mfpdm Posted March 29, 2007 Share Posted March 29, 2007 I think this might be the one. :cheers: Link to comment Share on other sites More sharing options...
jage Posted March 29, 2007 Share Posted March 29, 2007 Yeah, I was almost too lazy to even post those pics... Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 29, 2007 Share Posted March 29, 2007 I couldn't find them... Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 29, 2007 Share Posted March 29, 2007 Maybe I'll narrow it down as that's an overwhelming list... The 4wd front axle on ALL MJs is the high-pinion Dana 30. For your 88 year, the rear axle is most likely a D35, but potentially a D44. If your rear axle's cover is egg-shaped it is a D35. If it is the retarded diamond (see pictures...) then it is a D44. Link to comment Share on other sites More sharing options...
jage Posted March 29, 2007 Share Posted March 29, 2007 Ha! Well I made a stupid mistake (corrected now) of putting the D30 next to the D44... duh! Of course the d30 is front and you're probably wondering about rear... So question is, is there more than a remote possiblity that something other than a D35 or D44 is under his comanche? Like were they made with AMC20s ever... reason being he doesn't have to compare like, the Ford 7.5" shape for example... Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 29, 2007 Share Posted March 29, 2007 So question is, is there more than a remote possiblity that something other than a D35 or D44 is under his comanche? Like were they made with AMC20s ever... reason being he doesn't have to compare like, the Ford 7.5" shape for example... Unless it isn't factory, no. The Eaton 20 was only in 86. Otherwise they're D35s or D44s. FWIW, South America export versions optionally have D44 fronts. (At least on XJs) But I doubt we'll see that. Link to comment Share on other sites More sharing options...
Eagle Posted March 29, 2007 Share Posted March 29, 2007 FWIW, South America export versions optionally have D44 fronts. (At least on XJs) But I doubt we'll see that. No, they don't. XJs built in Venezuela for their local market had dana 44 fronts. The rest of South America got XJs and MJs right of the same assembly lines in the US of A that ours came from. I know that to be the case because my wife is from Chile and I have a friend in Chile who owns an XJ. And there are a LOT of older XJs down there I've looked over pretty carefully. Another urban legend ... down the tubes. Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 29, 2007 Share Posted March 29, 2007 FWIW, South America export versions optionally have D44 fronts. (At least on XJs) But I doubt we'll see that. No, they don't. XJs built in Venezuela for their local market had dana 44 fronts. The rest of South America got XJs and MJs right of the same assembly lines in the US of A that ours came from. I know that to be the case because my wife is from Chile and I have a friend in Chile who owns an XJ. And there are a LOT of older XJs down there I've looked over pretty carefully. Another urban legend ... down the tubes. Okay, well, it was only ones from venezuela that I'd ever seen. I actually assumed that all of the S. America ones were built there. Meh. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 29, 2007 Share Posted March 29, 2007 Here is a pic of a 20 in a MJ, only avalible in 1986 from the factory and even then only on the one ton version: Here is a D44 cover. (If you sharp, you will notice this is actually a FRONT cover. by the position of the fill plug.): Image Not Found Here is a D44 in a MJ: Image Not Found Here is a D35 "C" Clip cover (Not avalible till aft 1990): Image Not Found And lastly here is a NON "C" Clip cover in a MJ (This is most likely what you have): Image Not Found These are all the possible FACTORY options for rear axles you could have in your truck. If someone swapped in another axle along the way, well we couldn't possibly know. If you can post up a pic and then we will tell you exactly what you have. CW Link to comment Share on other sites More sharing options...
jage Posted March 29, 2007 Share Posted March 29, 2007 So, visually can you tell the difference from a C-clip or a non- C-clip based on the diff cover? It looks like the non C-clip is sharper between the two photos (the extrusion of the C-clip seems more rounded)... is this just paint or a visual effect, or is it an externall identifiable feature? Link to comment Share on other sites More sharing options...
Eagle Posted March 29, 2007 Share Posted March 29, 2007 Okay, well, it was only ones from venezuela that I'd ever seen. I actually assumed that all of the S. America ones were built there. Meh. So did I. I was totally shocked the first time I crawled under Miguel's XJ and saw a Dana 30. And a Chrysler 8.25 rear. Then I asked him about the stories of all the South American XJs all having D44s all around and he told me that was only the ones built in Venezuela. Still as stupid as usual, I then asked him where the heck his XJ came from, and he said "Off a boat. It was built in the same factory yours was." The interesting thing for me (beyond that revelation) is that almost every XJ (and the two MJs) I've seen in Chile had the factory hidden winch option. Apparently any SUV-type vehicle in Chile with a winch on the front gets taxed as a "work truck" rather than a family car and the difference in fees is significant. I've never seen a hidden winch in the U.S. but down there I see them in the parking lot at the market on a regular basis. Link to comment Share on other sites More sharing options...
comancheman Posted March 29, 2007 Share Posted March 29, 2007 wats better the c clip 35 or the non c clip 35? Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2007 Share Posted March 29, 2007 The non-C-clip is technically better, but only because when you snap the axle shaft, the tire will still be attached to the truck and not wander away. :D And someone can correct me here, but I think the older axle should have the rubber plug in the cover and the later axles should the threaded steel fill plug, yes? Don't know if it directly corresponds with the C-clips, but I'm betting all the rubber plug axles are non-C-clip Link to comment Share on other sites More sharing options...
87manche Posted March 29, 2007 Share Posted March 29, 2007 I think you might have that backwards Pete, I've got three non c 35's here and they all have steel plugs. axle years I've got here: 86 2.5L AX4 87 4.0 AX-15 90 4.0 Aw4 Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2007 Share Posted March 29, 2007 Might be. Wouldn't be the first time. :roll: Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 29, 2007 Share Posted March 29, 2007 Either way it's a D35 and it's not worth the rubber or the steel in the plug. Link to comment Share on other sites More sharing options...
comancheman Posted March 29, 2007 Share Posted March 29, 2007 nice one dirty, but my 88 d35 had a rubber plug and so does my 90 Link to comment Share on other sites More sharing options...
mfpdm Posted March 30, 2007 Share Posted March 30, 2007 I'm a little confused about the clip and non clip and the plugs. 35C indicates clip right? Here is the axle in the 88 MJ. It came from a YJ (not sure of year) and has 35C on it and a rubber plug. Now here is the pic of the axle in the 89 XJ I'm using for parts. It has 35C and a steel plug. :hmm: Link to comment Share on other sites More sharing options...
Eagle Posted March 30, 2007 Share Posted March 30, 2007 I'm a little confused about the clip and non clip and the plugs. 35C indicates clip right? Nope. They're all 35c. The 'C' stands for "Customer," and it was Dana-Spicer's way of denoting an axle that was shipped partially assembled, for "Customer completion." The older ones have the threaded pipe plug, the newer ones have the rubber plug. Link to comment Share on other sites More sharing options...
mfpdm Posted April 1, 2007 Share Posted April 1, 2007 Thanks, I've read that before but just forgot until you refresh my memory. That seems to happen more often than I'd like to admit. :D Must need more beer. :cheers: Link to comment Share on other sites More sharing options...
