Altinator Up Grade Options
'87 MJ uses a Delco Remy,think GM, alternator. Delco Remy alternators are available in just about any configuration and output you can imagine. Hit the JY and start looking, or ask the parts guy at the local auto parts store.
ACDELCO Part # 3342417
{#19135975} Remanufactured; 105 Amp
GENERATOR w/A/C; DELCO CS130 105 AMPS
i have an 87 mj with a 2.5 liter. the alt just died so i would like to up grade with something that has more amp output. what options do i have?
  • 9 months later...
I think the only difference is output........not size and shape.
The Caprice is off the shelf, if you need one now.......go get it.
If you want a 200 amp or some other........order and wait.
I did what I did because I wanted.......needed........one that day and needed a higher amp than the 70amp that is stock.
