tmaxx411
939 profile views
tmaxx411's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. So long time since an update... The body shop held onto the truck for over a year and made zero progress on it... So it moved back home and now I'm doing all the panel replacements. Currently has no floor at all, and Ithat is good, because even after blasting I found more rust under the floor braces
  2. windshield frame is heavily rotted, firewall and floor pan are much cleaner in the xj.. the ones in the mj are beginning to rot as well. front headlight buckets are different for the 87+ latch system, as well as a few other panels are slightly different. also need to sort out the door strikers for 97+ doors.. scheduled for another visit tomorrow afternoon with their body guy to go over what I'm looking to do.
  3. when they said cab, they mean rockers, floor, firewall, inner fenders, and windshield frame good to know the rockers arent the same... ill be sure to let them know. maybe they can do it without messing with the rockers
  4. I trust this shop to do it correctly. And it's getting a 97+ interior, along with an LS, so the 2000 cherokee will actually be more correct for this project
  5. truck has been at the body shop for a few weeks now.. went through everything with them and discussed what i would like to accomplish. they advised me to consider an entire cab replacement, vice just replacing the panels i needed. so.. pending a final price, the entire cab of the comanche will be removed, and the front of a 2000 cherokee will be put back.
  6. new (used) engine
  7. donor parts
  8. figured id start a log of this project. truck began its life as an 86 with a 2.5, rwd, 3 speed auto. rebuilding it to be more modern, with more power, and more reliability too.
  9. Sorry for the delay. Here's a bunch of pictures of the current engine mount setup and bracketry, as well as the transfer case drop, transfer case/ceossmember mounting positions, and a close up of the shifter clearance issue
  10. I'm using an xj shifter. It's not hitting the dash, it's hitting the center console.
  11. The motor did not come out for this work. It stayed bolted up the whole time
