Bmoore2 Posted March 28, 2013 Share Posted March 28, 2013 Hey guys, My mechanic is having one hell of a time with this Spartan locker and carrier in my dana 30. The line up pin that goes in the carrier through the locker is not lining up right. What is the fix? It's getting really frustrating. Can someone please help me? I'm am sure I have the right carrier as I have ordered 2 thinking the first one was wrong. The locker is the spartan for dana 30. I can get part number if that would help. Link to comment Share on other sites More sharing options...
88mjgilley Posted March 29, 2013 Share Posted March 29, 2013 did you accidentally get a locker for the jk and not a xj mj i just installed my spartan last week and everything went perfect Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 29, 2013 Author Share Posted March 29, 2013 Spartan Lockers Spartan Lockers SL D30-27 That is the locker I bought Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 29, 2013 Author Share Posted March 29, 2013 I just watched a video of a spartan install. If he has not removed the little pins that hold the springs down before trying to insert the line up pin will that cause it not to line up right? The locker hole is not lining up with the large cross pin and the carrier hole. Sorry I had to do a little more digging. Link to comment Share on other sites More sharing options...
SW86 Posted March 29, 2013 Share Posted March 29, 2013 edited sorry Link to comment Share on other sites More sharing options...
MJ_Milam Posted March 29, 2013 Share Posted March 29, 2013 have you talked to anyone from standard gears? they list a part number for a carrier that works with the locker Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 29, 2013 Author Share Posted March 29, 2013 I bought the second carrier from rob at rwkhaussupply.com. He insured me I have the right carrier. I am wondering if he is installing it wrong. I don't think he has pulled the pins that hold the 4 springs down. I am just very frustrated... I want my truck back. Link to comment Share on other sites More sharing options...
MJ_Milam Posted March 29, 2013 Share Posted March 29, 2013 those pins are for installation. once the locker is in the carrier you remove them Link to comment Share on other sites More sharing options...
ComancheKid45 Posted March 29, 2013 Share Posted March 29, 2013 He quite possibly has the locker installed backwards inside the carrier, itll only sit in there 1 way for the cross pin to completly be installed. I ran into the same issue when i rebuilt mine a few weeks ago, he'll have to get everything out, reassemble, and reinstall the opposite direction ;) Link to comment Share on other sites More sharing options...
mnkyboy Posted March 29, 2013 Share Posted March 29, 2013 I would be worried about your mechanic, the spartan is probably the easiest locker on the market to install. Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 30, 2013 Author Share Posted March 30, 2013 No it's the carrier.... I thought the same thing. The pin from the locker will not go thru the carrier. The stock pin from from the 30 will not go thru the carrier. Yukon carrier will not take the pin. Super frustrated. Well just got some good news.... Machine shop straightened out the lop-sided hole bored in the carrier. Everything is FINALLY COMING TOGETHER!!!!!!! I would be worried about your mechanic, the spartan is probably the easiest locker on the market to install. Link to comment Share on other sites More sharing options...
89eliminator Posted March 30, 2013 Share Posted March 30, 2013 your mechanic seems like a hack..... if what he says is true, why wouldn't you or him get a new carrier? i would call the vendor and get one overnighted for free. Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 30, 2013 Author Share Posted March 30, 2013 I got 2 carriers from Yukon. Both were the same. The carrier hole was tapped wrong. I was so pissed I went to look for myself. Just an FYI.... Yukon carriers for a dana 30 are not tapped correctly. The hole was oblong and not round. And not even the factory pin would go in. Both pins would fit the factory carrier perfect. My opinion Yukon is junk But it's straightened out now. Machine shop tapped the holes correctly and it's installed. Hope to have my truck back in a few days. Thanks again fellas Link to comment Share on other sites More sharing options...
mvusse Posted March 30, 2013 Share Posted March 30, 2013 And what was wrong with the stock Dana carrier? Link to comment Share on other sites More sharing options...
mnkyboy Posted March 30, 2013 Share Posted March 30, 2013 And what was wrong with the stock Dana carrier? He is going to 4.56 gears so the stock carrier won't work. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 30, 2013 Share Posted March 30, 2013 I got 2 carriers from Yukon. Both were the same. The carrier hole was tapped wrong. I was so pissed I went to look for myself. Just an FYI.... Yukon carriers for a dana 30 are not tapped correctly. The hole was oblong and not round. And not even the factory pin would go in. Both pins would fit the factory carrier perfect. My opinion Yukon is junk But it's straightened out now. Machine shop tapped the holes correctly and it's installed. Hope to have my truck back in a few days. Thanks again fellas Did you contact the vendor or Yukon to let them know there is a problem? Link to comment Share on other sites More sharing options...
Bmoore2 Posted March 30, 2013 Author Share Posted March 30, 2013 No I am going to Monday morning when I return the extra one. I also thought my mechanic was an idiot.... But the pin just won't fit. Ill let you guys know what Yukon says after I call them. Link to comment Share on other sites More sharing options...
eduardostewart Posted June 8, 2014 Share Posted June 8, 2014 what was your final outcome? Link to comment Share on other sites More sharing options...
