Goose Posted December 18, 2012 Share Posted December 18, 2012 I've got the Dana 30 up front, Dana 35 in the rear, 4.0, 5speed. 31" tires. I want to go to 4.10, but I need to know where to look, and what gear companies you recommend. Link to comment Share on other sites More sharing options...
mvusse Posted December 18, 2012 Share Posted December 18, 2012 If you have to ask, you do not have the tools nor the knowledge to install the gears yourself. If you are going to pay somebody to do that for you, you will pay more than it would cost for a set of junk yard axles that already have 4.10 gears. Look for a 4wd Cherokee with a 4 cylinder/5 speed stick. Front axle will bolt in, rear axle will need a bit of cutting with an angle grinder, new spring perches (cheap) and $20 paid to a welding shop to make it bolt in. You should be able to get both axles for ~$350. That is quite a bit less than you will per axle to have your current ones regeared ($500-$800, for a total of $1000-$1600). Link to comment Share on other sites More sharing options...
Goose Posted December 18, 2012 Author Share Posted December 18, 2012 I belong to a great jeep club with many skilled individuals whom I could call on for help. I should've been more specific and said what other ring and opinion will work in my current diffs, what axles are easiest to swap, and which supermarket companies have you had the best luck with. Link to comment Share on other sites More sharing options...
Goose Posted December 18, 2012 Author Share Posted December 18, 2012 *pinion Smart phone out smarted me. Link to comment Share on other sites More sharing options...
Globex Posted December 18, 2012 Share Posted December 18, 2012 We use Yukon for almost everything around here and sometimes USA standard. Make sure you have the correct carrier for both diff's before you tear them down. Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2012 Share Posted December 18, 2012 all I can add is please don't spend a dime on upgrading the Dana 35. invest your money into an axle that'll last. :thumbsup: Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted December 18, 2012 Share Posted December 18, 2012 :agree: , on both accouts ditch the D35 and have the new gear set professionally installed. That is, unless one of your buds IS a professional Link to comment Share on other sites More sharing options...
Goose Posted December 18, 2012 Author Share Posted December 18, 2012 Ok, I've found a guy here on Craigslist who has an 8.8 with 4.56 and an arb air locker as well as a Dana 30 with matching gears and a trutrac. He's asking $700. Good deal or not? Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted December 18, 2012 Share Posted December 18, 2012 Ouch. :ack: Even if the D30 is an HP and neither axle has ever been used and was just painted. I'm thinking $500, my humble opinion only. Link to comment Share on other sites More sharing options...
Pete M Posted December 19, 2012 Share Posted December 19, 2012 it's not completely outrageous, but a little high. whatever you do, don't assume that everything is perfect inside the axles. pop the covers and inspect. :thumbsup: Link to comment Share on other sites More sharing options...
mnkyboy Posted December 19, 2012 Share Posted December 19, 2012 That seems like a good deal if its all in good shape,what are they out of? Ouch. :ack: Even if the D30 is an HP and neither axle has ever been used and was just painted. I'm thinking $500, my humble opinion only. I'm gonna guess that you have never priced lockers. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted December 19, 2012 Share Posted December 19, 2012 I'm gonna guess that you have never priced lockers. I've priced a few, but never bought. . . some what, guilty as charged :oops: Link to comment Share on other sites More sharing options...
Eagle Posted December 19, 2012 Share Posted December 19, 2012 Ok, I've found a guy here on Craigslist who has an 8.8 with 4.56 and an arb air locker as well as a Dana 30 with matching gears and a trutrac. He's asking $700. Good deal or not? With an ARB in the rear and a Trutrac in the front, that's a steal -- if you want or need an ARB and a Trutrac. If you don't need 'em, then you're paying for expensive toys you won't be getting full value from. Link to comment Share on other sites More sharing options...
BIGHEEP Posted December 19, 2012 Share Posted December 19, 2012 Ok, I've found a guy here on Craigslist who has an 8.8 with 4.56 and an arb air locker as well as a Dana 30 with matching gears and a trutrac. He's asking $700. Good deal or not? A new ARB is almost a grand alone. Link to comment Share on other sites More sharing options...
Pete M Posted December 19, 2012 Share Posted December 19, 2012 and that's why I say check the condition extra thoroughly. Link to comment Share on other sites More sharing options...
nickhuts Posted December 28, 2012 Share Posted December 28, 2012 They only way you will learn is to do it yourself. By ya a set. Have a buddy come over that has done it before and get er done! I have Motive Gears in mine right now. They are cheap and they hold up to 37s. No complaints here. don't waste your money on high priced gears. I also have a Spartan locker in the rear that hold up to street driving and trails. Maybe one day it will go..but as of now I stand behind them! Link to comment Share on other sites More sharing options...
