88whitemanche Posted December 12, 2012 Share Posted December 12, 2012 What's up guys i plan to replace mine in the near future and I have an internal slave but I want to know how to bleed the master cylinder Any tip and experience will help al Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted December 12, 2012 Share Posted December 12, 2012 I need to know this to, :popcorn: I bet there answer will probably be to covert to external. :laughin: Link to comment Share on other sites More sharing options...
Biotex Posted December 13, 2012 Share Posted December 13, 2012 I just got finished installing a new master and slave on my YJ. I filled the reservoir up with new fluid, and opened up the bleeder. I depressed the clutch and held it to the floor until the bleeder is tight, then let up on the clutch pedal. Open the bleeder. Depress the pedal and hold it down. Close bleeder. Let pedal up. Open bleeder. Depress pedal and hold. Check reservoir level and add fluid as necessary. Close bleeder. Let pedal up. Open bleeder. Depress pedal and hold. and on and on and on until all air is out. The other method is if you don't have a helper with a strong foot.... open the bleeder and attach some new clean clear tubing on to the end of the bleeder with it kept open. Put the end of the tube into a jar of new brake fluid. A clear jar is best so you can see the bubbles coming out. Elevate the jar so it is as close to the bleeder as possible. The end of the tube needs to stay submerged at all times. Pump the clutch slowely and the air will be forced out into the jar and escape as bubbles. When you let up on the pedal, it will try to suck backwards through the tube, but since the end of the tube is submerged in brake fluid, it will only suck in fluid not air. You do it until you see no more bubbles in the jar. Then close the bleeder and see if it feel right. If it doesn't , you convert to an external slave... :yes: Link to comment Share on other sites More sharing options...
88whitemanche Posted December 13, 2012 Author Share Posted December 13, 2012 Um....where is the bleeder exactly? Sorry I'm a rookie at this trying to get it right the first time Link to comment Share on other sites More sharing options...
87MJTIM Posted December 13, 2012 Share Posted December 13, 2012 You bleed from the slave cyl, not the master. For the slave, you have to get under the jeep. Look for two tubes coming out of the bell housing. One will end with a bleeder nipple on it. You can use the jar/fluid method above or get a vacuum bleeder. If you are solo, be prepared to get up and refill the master, then back down under to operate the bleeder. Link to comment Share on other sites More sharing options...
Biotex Posted December 13, 2012 Share Posted December 13, 2012 This is the slave on my YJ. See the two lines exiting the bell housing? One goes to the master cylinder, and the other just ends with a bleeder attached. They are on the driver side. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 18, 2012 Author Share Posted December 18, 2012 Any one with pics of the ax5 bleeder hose? I looked under there to day and didn't see another line coming of the tranny just the one coming to the clutch master fylinder Link to comment Share on other sites More sharing options...
Biotex Posted December 18, 2012 Share Posted December 18, 2012 Maybe this post will help. http://comancheclub.com/topic/22972-slave-cylinder-location/ Link to comment Share on other sites More sharing options...
88whitemanche Posted December 18, 2012 Author Share Posted December 18, 2012 It actually did help I saw that same bleeder Hose but didn't want to mess with unless I knew what it actually was Thanks for your input guys beers on me!!!! Link to comment Share on other sites More sharing options...
JFAComanche6 Posted December 18, 2012 Share Posted December 18, 2012 Usually, if you put on a new or good master or slave cylinder, put it all together, and pump the clutch pedal like crazy and it will bleed itself. but do it then wait a couple hours between pumping, Id say 3 or 4 times is good. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 18, 2012 Share Posted December 18, 2012 Usually, if you put on a new or good master or slave cylinder, put it all together, and pump the clutch pedal like crazy and it will bleed itself. but do it then wait a couple hours between pumping, Id say 3 or 4 times is good. sounds about like what i did, installed a new slave, filled the master, pumped it about 30-40 times, checked fluid level and added fluid, bumped it till it was firm, added fluid if needed, waited a couple hours for the little bubbles to go away and pumped it some more. it is not the "proper" way but it worked for me and i have a nice firm petal without any slack Link to comment Share on other sites More sharing options...
Biotex Posted December 18, 2012 Share Posted December 18, 2012 I believe most of the replacement slaves are self bleeding. I do not how to tell the difference. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 20, 2012 Author Share Posted December 20, 2012 Is it weird that the bottom of the bell housing is full of clutch fluid instead of the wall by the fuse panel? Link to comment Share on other sites More sharing options...
Biotex Posted December 20, 2012 Share Posted December 20, 2012 Is it weird that the bottom of the bell housing is full of clutch fluid instead of the wall by the fuse panel? Not at all. Just means the slave cylinder is leaking and not the master cylinder. On a side note: You should have seen the strange look my Aunt gave me the other day when I mentiond needing to "bleed the slave after changing the master". I kid you not she was puzzled and bothered enough to pull me aside to explain myself. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 20, 2012 Author Share Posted December 20, 2012 Lmfao hahaha no way! Hahahaha and thanks for the info I think I might just park the jeep because if the slave cylinder I might as well change cthe whole shebang with the clutch assembly Link to comment Share on other sites More sharing options...
Biotex Posted December 20, 2012 Share Posted December 20, 2012 Lmfao hahaha no way! Hahahaha and thanks for the info I think I might just park the jeep because if the slave cylinder I might as well change cthe whole shebang with the clutch assembly That's the best way to buy the parts actually. They sell it as a kit. Clutch, pressure plate, slave, pilot bearing even comes with the alignment tool. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 21, 2012 Author Share Posted December 21, 2012 Ok cool ill keep that in kind Link to comment Share on other sites More sharing options...
Eagle Posted December 21, 2012 Share Posted December 21, 2012 I believe most of the replacement slaves are self bleeding. I do not how to tell the difference. The replacement slaves come with a big zip tie holding them in the compressed position. You are NOT supposed to cut that tie when you install the slave cylinder. After everything is buttoned up, the zip tie is intended to break the first time you step on the pedal, so when the bellows expands it pulls brake (clutch) fluid into the slave from the master cylinder. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 21, 2012 Author Share Posted December 21, 2012 Do u think its a good idea to get like. Stage 2 clutch kit? Link to comment Share on other sites More sharing options...
Biotex Posted December 21, 2012 Share Posted December 21, 2012 I don't know what a stage II clutch kit is, but if it is a high performance clutch kit, there is a good chance it will require a lot more force to depress the pedal. Keep that in mind if you do a lot of city driving. Stiffer clutches are for high performance applications where you don't want slippage. Like drag strips... A waste of money IMO. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 21, 2012 Author Share Posted December 21, 2012 Sorry not a stage 2 clutch lit I mean like a center force clutch kit....do anyone know if their worth it or just stick to stock? I mean I've been so used to heavy traffic that driving stick on crazy traffic days is like 2nd nature to me I mean I don't mind the grind of pushing the pedal 50 times in a 45min traffic jam lol Link to comment Share on other sites More sharing options...
