Muffler Sound
Hey guys,
So most of you may or may not know, I am the son of Akula69 who runs around on here from time to time. When I was 15 we started a restoration on my 1989 Comanche. We finished it up in August of 2010 and I have been drving it around ever since, and keeping up with maintenance. Having driven it to college and back quite a few times, the mileage has been getting up there. We found a suitable 1999 Cherokee and are planning a 97+ swap this summer. We have both looked at threads of others who have come before us, and have seen what it takes and are pretty confident either way (although working on these trucks rarely ever goes as planned as we all know). However, I was struck by an interesting thought the other day. Right now I am running a Flowmaster 40 on the 4.0. With the change to the 4.0 H.O., how will this affect the sound of the exhaust? Will the tone get "tinnier", or deeper? A trivial question I know, its just an itch I wanted to scratch.
Ryan
I had a Thrush glass pack that I happened to have laying around on my 94 XJ and ended up installing a stock muffler because the drone was too loud for my comfort. It is now on my trail truck with just a front pipe in front of it, no cat, no tailpipe and is a lot quieter than it was on the 94 HO engine.
Don't know about the Flowmaster, but do expect the sound to be a bit louder than what you have now.
I know this is a comparing apples to oranges but when I swapped the totally stock 2.8 out for the 3.4 with edelbrock intake I was curious if it was going to sound different and it sounded exactly the same so take it for what it's worth.
I had one, couldn't stand the obnoxious drone. It didn't last long on my rig. I think it was caused by the 2.5" pipes all the way and the header though.
I have 2.5" pipes from the cat -> to the back.
Mine sounds pretty nice, You can just barely hear the exhaust while driving. Almost wish it was a bit louder lol
Screams when you floor it though
Well, I have heard it and its loud, especially in 2nd gear. However, I believe it will tone down some when we complete the 99XJ HO transplant, as we will have to splice the cat from the 99 onboard to get the O2 sensor bungs (to make the obdII work).
It does have a nice low tone at idle....
For lack of a better question yes sir. I still run the stock up to the cat
Stock is 2-1/2" up to the cat -- and out of the cat. The connector from the cat to the muffler necks down to 2-1/4", and the muffler inlet is 2-1/4".
I don't think the change to an HO will make the exhaust sound any different at all. I used to spend a lot of time on trail rides watching different XJs negotiate obstacles, and they all sounded pretty much the same. It isn't very exciting, because with an in-line 6 the power pulses are all perfectly evenly spaced, so the exhaust can never get that lumpy "cammed" sound you get with V8s. I ran a 2-1/2" turbo system on my '88 XJ for awhile and I hated it. It was louder than stock but didn't sound any better, plus it hurt my low-end torque and cost me gas mileage. It was the first (and last) time in my life I actually looked forward to the day when I needed to replace the exhaust system.
If you want a Jeep I-6 to sound good ... go Gibson.
Unless you have a stroker. Even with a mild cam. :thumbsup: If you want a Jeep I-6 to sound good ... go Gibson stroke it. :yes:
