Comanche County Posted September 26, 2012 Share Posted September 26, 2012 Time to replace the MJs cracked window and door seals. Anyone recommend a supplier with quality parts? I could grab some JY stuff, but I want new rubber. Link to comment Share on other sites More sharing options...
sinkrun Posted September 26, 2012 Share Posted September 26, 2012 Team cherokee Link to comment Share on other sites More sharing options...
Pete M Posted September 26, 2012 Share Posted September 26, 2012 the inner left door window wipe works for the outer right door and vise-verse. also, 97+ cherokee door seals are bigger than the older style. So you should be able to go to a junkyard and get good parts rather than ancient crappy stuff. :thumbsup: Link to comment Share on other sites More sharing options...
neohic Posted September 26, 2012 Share Posted September 26, 2012 I like pulling door seal parts from two door XJs and trimming them down to fit. Then I can really cram a bunch in there nice and tight! Link to comment Share on other sites More sharing options...
Comanche County Posted September 26, 2012 Author Share Posted September 26, 2012 Good ideas, thanks! Link to comment Share on other sites More sharing options...
dave92cherokee Posted September 27, 2012 Share Posted September 27, 2012 The grand cherokee door seals are also an upgrade that alot of the xj guys use and could be used as well on mj's. Link to comment Share on other sites More sharing options...
Comanche County Posted September 27, 2012 Author Share Posted September 27, 2012 Didn't think of that either. Good idea. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted September 28, 2012 Share Posted September 28, 2012 Not to :hijack: but is it recommended to remove the dash to install the door seals? Or is there enough room to barely squeeze them in? Was pretty easy to remove at the junkyard, but I'm guessing it won't be that way to install. :ack: Link to comment Share on other sites More sharing options...
relyt120 Posted September 28, 2012 Share Posted September 28, 2012 No, Loosen the trim and put the new one in right behind the old one you are removing to hold the crevice open. Link to comment Share on other sites More sharing options...
johnj92131 Posted September 28, 2012 Share Posted September 28, 2012 The grand cherokee door seals are also an upgrade that alot of the xj guys use and could be used as well on mj's. What years of the Grand Cherokee?? Is this the same years as the XJ? I see lots of mid 90's Grands in the local junk yards, not so many late XJ's Link to comment Share on other sites More sharing options...
dave92cherokee Posted September 28, 2012 Share Posted September 28, 2012 If I remember correctly it was from the late 90's zjs like 95-99. Link to comment Share on other sites More sharing options...
