Zenobian_84 Posted July 5, 2012 Share Posted July 5, 2012 I'm thinking of possibly getting another 2.5 engine down the road to tinker with / disassemble to add things to my own. How much does a fully dressed 2.5 weigh? And by "fully dressed" I mean, a complete block w/out a tranny, with full options on the motor (a/c components etc.)? Just want to get a rough estimate to see if I can just use my MJ to go pick it up. I read on a post a while back that it weighs close to 800 lbs, but I can't remember if that's with or w/out the tranny; is that right? On a related note, if I were to pick up a 4.0, how much does that weigh in at? Same conditions as the 2.5. Link to comment Share on other sites More sharing options...
Alexia Posted July 5, 2012 Share Posted July 5, 2012 A 4.0L with transmission and accessories is around 750 pounds. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted July 5, 2012 Author Share Posted July 5, 2012 A 4.0L with transmission and accessories is around 750 pounds. So it's probably safe to assume that a 2.5 with transmission and accessories is just shy of 650 lbs most likely? Also, on an unrelated note, is your icon from an anime, or from a very detailed drawing? I've been wondering that for the longest time now... :yes: Link to comment Share on other sites More sharing options...
Eagle Posted July 6, 2012 Share Posted July 6, 2012 I'm thinking of possibly getting another 2.5 engine down the road to tinker with / disassemble to add things to my own. How much does a fully dressed 2.5 weigh? And by "fully dressed" I mean, a complete block w/out a tranny, with full options on the motor (a/c components etc.)? Just want to get a rough estimate to see if I can just use my MJ to go pick it up. I read on a post a while back that it weighs close to 800 lbs, but I can't remember if that's with or w/out the tranny; is that right? On a related note, if I were to pick up a 4.0, how much does that weigh in at? Same conditions as the 2.5. I picked up a 2.5L with auto tranny (but no transfer case) in my MJ and didn't even know it was there. Also hauled a 4.0L with 5-speed & transfer case with no problems. You're looking at maybe half the rated capacity of your MJ. Link to comment Share on other sites More sharing options...
carnuck Posted July 19, 2012 Share Posted July 19, 2012 I picked up and loaded my son's '90 2.5L complete with flywheel and put it in the back of my '82 Chev. I'd say about 250 lbs. I can't lift 500 like I used to! Link to comment Share on other sites More sharing options...
johnj92131 Posted July 19, 2012 Share Posted July 19, 2012 I'm thinking of possibly getting another 2.5 engine down the road to tinker with / disassemble to add things to my own. How much does a fully dressed 2.5 weigh? And by "fully dressed" I mean, a complete block w/out a tranny, with full options on the motor (a/c components etc.)? Just want to get a rough estimate to see if I can just use my MJ to go pick it up. I read on a post a while back that it weighs close to 800 lbs, but I can't remember if that's with or w/out the tranny; is that right? On a related note, if I were to pick up a 4.0, how much does that weigh in at? Same conditions as the 2.5. Red Rocker79: Do us all a favor when you load that 2.5 into your truck by running the truck over some scales with the load and then with the truck empty. That way, we will all have a valid weight for next time the question comes up! Link to comment Share on other sites More sharing options...
carnuck Posted July 19, 2012 Share Posted July 19, 2012 4.0L weighs about 65lbs more than 2.5 (I can lift a complete block and carry it, but not a longblock) Link to comment Share on other sites More sharing options...
AMC-MJ Posted July 19, 2012 Share Posted July 19, 2012 Well my Comanche has hauled AMC-V8s around, It actually carried one all day every day for 5mo nobody would help unload it ! I actually herniated my groin when I unloaded it myself ! ! I also used to load a pallet of salt on the bed for salting commercial sized condo walks in the winter time ! ! ! Truck's previous owner towed his fishing boat with it all the time too. My truck is a shortbed 2wd, AMC-2.5 I4, AX-4 4spd, D35 with 3.73s Mike Link to comment Share on other sites More sharing options...
