rear 4 link?
I run SOA on the rear with longer shackles and I've been told my truck "flexes like crazy". I can pick any tire up 41" before another lifts, limited by my shocks. With the shocks disconnected I can go more, but then the brake hoses are too short.
-V8 Grand Cherokee coils used in the rear
-Trail Gear Rod Ends @ the diff
-Chevrolet truck leaf spring bushings at the chassis end
-Triangulated 4 Link Rear
-Run of the mill Rancho's
Works Ok
Same here
Have you flexed it on a ramp or with a forklift to see what is limiting it? If you don't have acess to either you can bring it to my shop and flex it with the forklift.
Based on that picture it looks like your rear suspension isn't doing much, the rear axle looks pretty parallel to the body still. Your front is doing all of the work.
Edit: not trying to be mean, just pointing out my observation.
