Minuit Posted June 12, 2012 Share Posted June 12, 2012 1991 ENGINE & PERFORMANCE: Stock engine and transmission with no modifications. DRIVETRAIN: 2 wheel drive. AW4 automatic transmission with floor shift, open differential Dana 35 rear axle. COOLING: CSF 3-core radiator with Hayden 678 automatic transmission cooler. Stock replacement heater core, water pump, and thermostat. ELECTRICAL & IGNITION: 94-97 distributor with external camshaft position sensor. Stock replacement ignition components. Power windows, mirrors, and door locks. STEERING: Stock; 12.7:1 ratio steering gearbox SUSPENSION: WJ Grand Cherokee control arms, 28mm front sway bar. INTERIOR: Luggage Fabric wingback flip-forward bucket seats, Limited door panels, full center console, carpet, and sound insulation. Stock RX-171 radio with auxiliary input, 6 speakers, and 180W Alpine amplifier. Factory cup holder. New aftermarket carpet. Export 125 mph speedometer with correct mileage. Interior fully soundproofed with mass-loaded vinyl. AIR CONDITIONING: New-build 1995-1996 R-134a native system with OEM SD7H15 compressor, parallel-flow condenser, and NOS evaporator. Factory evaporator temperature probe retained. BRAKES: Front and rear disc brakes. Rear disc brake setup sourced from 93-98 Grand Cherokee. LIGHTING: Relay-controlled headlamps with Hella H4 composite housings. Factory retrofit fog lights, wired in stock configuration. WHEELS/TIRES: 15x8 Jeep "Ravine" wheels with 235/75/R15 Michelin Defender LTX M+S tires. MISCELLANEOUS: Silver Star Metallic exterior with 'squiggly' SporTruck graphics package. Engine: 4.0L High Output Transmission: AW4 (floor shift, originally column shift) Rear Axle: Dana 35 Wheelbase: Short Exterior Color: Silver Star Metallic with red SporTruck graphics package Interior Color: Charcoal with bucket seats (originally with bench seat), modified with factory convenience and comfort options including power windows and locks. Build date: April 17, 1991, 12:55 PM Current Location: Middle TN Status: Fair weather driver Mileage: 189,000 Current owner: Minuit Build Threads: 2012 - present, owned by Minuit Original factory options (all option names and descriptions from 1991 Jeep sales brochure) - 4.0L "Power Tech" I6 engine - Air conditioning - AW4 automatic transmission with column shift - Bench seat with adjustable headrests, Jamaica fabric - Black textured vinyl floor covering - Charcoal interior - Cigar lighter (yes, that was optional) - Heavy Duty Alternator and Battery Group (90A) - Radio Delete - Rear step bumper (yep, that too was optional) - Silver Star Metallic Clearcoat paint - Variable ratio power assist steering Added 1991-era factory options - options not originally available on 1991 Comanches in italics. - AM/FM electronically tuned stereo cassette with Dolby system (auxiliary input added), six speaker "Accusound by Jensen" sound system with dash-mounted tweeters and power telescoping antenna . (all speakers aftermarket, with re-used factory hardware) - Color keyed cab carpeting - Color keyed custom vinyl door panels with perforated vinyl upper, nylon carpeting lower, and plastic storage bin - Extra Quiet Insulation package - padding on back of cab, underhood insulation, and additional sound deadening materials - Front and rear mud flaps - Front bumper guards - Full center console with floor mounted transmission shifter - Gauge Group - tachometer, voltmeter, oil pressure and engine temperature gauges, low fuel indicator light, trip odometer, digital clock - Halogen fog lamps - Power Window & Door Lock Group (w/aftermarket keyless entry wired as factory) - Power Mirrors - Light Group - Ashtray light, courtesy lights, underhood light, headlamps-on warning buzzer, Sentinel headlamp switch - Recliner wingback bucket seats with adjustable headrests, Luggage fabric - Speed control - Tilt steering column, black - Visibility Group - left and right manual remote mirrors, intermittent wipers Link to comment Share on other sites More sharing options...
ComancheKid45 Posted June 13, 2012 Share Posted June 13, 2012 Pretty :eek: :drool: Link to comment Share on other sites More sharing options...
Minuit Posted June 13, 2012 Author Share Posted June 13, 2012 Pretty :eek: :drool: Thanks, I quite like it too! Your MJs are quite impressive themselves, and I especially love your Walker Evans truck. Link to comment Share on other sites More sharing options...
Minuit Posted January 19, 2013 Author Share Posted January 19, 2013 Edited to reflect some work that's been done, 'specially the new front end. More pics on the way soon. Link to comment Share on other sites More sharing options...
Minuit Posted September 30, 2013 Author Share Posted September 30, 2013 More pics! Link to comment Share on other sites More sharing options...
aditeman Posted July 2, 2014 Share Posted July 2, 2014 Wow this is a very well taken care of truck nice work Link to comment Share on other sites More sharing options...
Minuit Posted July 22, 2014 Author Share Posted July 22, 2014 Thank you very much! :thumbsup: Link to comment Share on other sites More sharing options...
88Pghcomanche Posted November 3, 2015 Share Posted November 3, 2015 Nice door panels. What did you swap them from? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 3, 2015 Share Posted November 3, 2015 http://m.ebay.com/itm/NOS-Jeep-Cherokee-front-door-panel-grey-power-84-96-XJ-sport-right-leather-/190867976249?nav=SEARCH Link to comment Share on other sites More sharing options...
88Pghcomanche Posted November 3, 2015 Share Posted November 3, 2015 http://m.ebay.com/itm/NOS-Jeep-Cherokee-front-door-panel-grey-power-84-96-XJ-sport-right-leather-/190867976249?nav=SEARCH Sweet. Thanks. Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *B1 TRIM STYLE B1 - CLOTH && VINYL BENCH SEAT -SA CHARCOAL 164 Zone 64-Memphis 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount ALA SE Decor Group ALK Italia Package APA Monotone Paint BAF 130 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PAC Silver Star Metallic Clear Coat QAC Silver Star Metallic Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body Model TL61 Build Date 4/16/91 Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: UNDERHILL MOTORS Dickson, TN Link to comment Share on other sites More sharing options...
