ZJ_flexxxer Posted May 14, 2012 Share Posted May 14, 2012 so i want to swap my axle under the leaf springs for an easy lift but i've read alot of mixed info on how much it lifts the rear of the truck. i've read anywhere from 3" to 5". so i was wondering if anyone out there just has pics of a before and after and i can judge for myself. Link to comment Share on other sites More sharing options...
Geonovast Posted May 14, 2012 Share Posted May 14, 2012 Amount of lift = axle tube diameter + two times spring perch height + thickness of springpack. Link to comment Share on other sites More sharing options...
ZJ_flexxxer Posted May 14, 2012 Author Share Posted May 14, 2012 Amount of lift = axle tube diameter + two times spring perch height + thickness of springpack. well i mean that's obvious but i would still like to see pics just to get an idea Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted May 14, 2012 Share Posted May 14, 2012 and if you could also recomend a quality lift kit for the front that would go with the SOA that would be great. sorry for the highjack. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2012 Share Posted May 14, 2012 thats soa rear and stock front,i ended up going about 6.5" up front to sit level SOA gives about 5" but you have to remember the rear is about 1"-2" taller stock so around 5" will give a stockish rake and around 6-6.5" will get it about level. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted May 15, 2012 Share Posted May 15, 2012 Nice, , but what lift did you go with for the front? Rocky road? Rusty's? Rough country? and after such a high lift have you had any problems with DW? Link to comment Share on other sites More sharing options...
Blue XJ Posted May 15, 2012 Share Posted May 15, 2012 You won't have any issues with death wobble because of the lift. If you do get a wobble its because something is worn out. I run 6.5" of lift with no sway bars or steering stabilizer for about 5 years and have never had a wobble or shimmy in the steering wheel. If something is worn (ball joints, hubs, tie rod end, control arm bushing, track bar......) you can very easily get a wobble. Link to comment Share on other sites More sharing options...
Zebvance Posted May 15, 2012 Share Posted May 15, 2012 This is a Rough country 4.5 inch lift with soa in the rear. I also believe there is 4.5-4.5 inch leaf packs in the back. The back sits 3 inches taller than the front. The PO did it..... :doh: If it doesn't have leaf packs it could have shackles and aal I'm not really sure. But I plan on Changing it asap and lifting the front 2 more inches. Link to comment Share on other sites More sharing options...
Pete M Posted May 15, 2012 Share Posted May 15, 2012 Going SOA lifts the back end up 5.5-6.5 inches over the current height. but how much lift you need in the front will depend on the condition of your leafs and if you want a bit of a rake to the truck (do you want it level when empty, or level with some stuff in the bed). and those numbers will change if you add in a heavy bumper, winch, etc. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 16, 2012 Share Posted May 16, 2012 Nice, , but what lift did you go with for the front?Rocky road? Rusty's? Rough country? and after such a high lift have you had any problems with DW? My lift isn't any ones kit. its a mixture of stuff,some of it I built myself. And as Blue XJ said,death wobble isn't caused by the amount of lift,its worn components and/or geometry issues. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted May 16, 2012 Share Posted May 16, 2012 just me personally, i think this is TOO high, it just looks too tall, overkill in my opinion, but you did say it was soa AND an extra sping pack right? not just an soa conversion? Link to comment Share on other sites More sharing options...
ZJ_flexxxer Posted May 17, 2012 Author Share Posted May 17, 2012 the pics definitely give me a better idea of what i need to complete my build. thanks to those who helped out. i just found a set of used 6.5" coils and control arms on my local craigslist for $150. hopefully i can snatch them up tomorrow after work. Link to comment Share on other sites More sharing options...
SW86 Posted May 18, 2012 Share Posted May 18, 2012 This is a Rough country 4.5 inch lift with soa in the rear. I also believe there is 4.5-4.5 inch leaf packs in the back. The back sits 3 inches taller than the front. The PO did it..... :doh: If it doesn't have leaf packs it could have shackles and aal I'm not really sure. But I plan on Changing it asap and lifting the front 2 more inches. take off that shackle lift for an original shackle and it should sit a little more level. Link to comment Share on other sites More sharing options...
