kawaboy13 Posted March 31, 2012 Share Posted March 31, 2012 I'm wanting to replace my stock headlamps due to limited visibility and I'm wanting the blue look. I saw that they have halos for our trucks and hid conversions. Which ones have y'all tried and does anyone know what all I will need? Is there a plug and play harness upgrade? Does anyone have pictures of the blue lights on there trucks or even the 6k ultra whites? Thanks in advance! Link to comment Share on other sites More sharing options...
cruiser54 Posted March 31, 2012 Share Posted March 31, 2012 http://www.eautoworks.com/Putco-H4--900 ... D7540.aspx Cruiser’s Headlight Upgrade Harness Instructions Absolutely plug and play. Remove grille and headlamp bulbs. I fed my harnesses from the passenger side starting between the battery and the back of the headlamp housing, over to the driver side. Plug the driver side bulb into the new harness. Attach the new harness's ground wire under one of the small bolts on the radiator support after scraping the paint off under it. Attach the harness to the existing harness behind the grille working toward the passenger side. . Plug the new harness plug into passenger headlamp. Plug original headlamp plug into receptacle on new harness. Attach the ground for the passenger side just like you did the driver side under a radiator support bolt. Attach relays with provided bracket on the passenger side inner fender. Connect power wires to battery. Link to comment Share on other sites More sharing options...
kawaboy13 Posted April 1, 2012 Author Share Posted April 1, 2012 Will this harness work with any type of lighting I decide to go with? Are there any suggestions on the light housing and bulbs? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 1, 2012 Share Posted April 1, 2012 Will this harness work with any type of lighting I decide to go with? Are there any suggestions on the light housing and bulbs? Yes. Do the harness first. You may decide, after seeing the improvement, that less ambitious plans will be needed for great headlights. Link to comment Share on other sites More sharing options...
kawaboy13 Posted April 7, 2012 Author Share Posted April 7, 2012 How bright are silver stars with the harness upgrade? Also what color do they shine? Thanks! Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 7, 2012 Share Posted April 7, 2012 How bright are silver stars with the harness upgrade? Also what color do they shine? Thanks! Don't waste your time and money on the SS........I did. Link to comment Share on other sites More sharing options...
mfpdm Posted April 8, 2012 Share Posted April 8, 2012 Don't waste your time and money on the SS........I did. Care to elaborate. Did you upgrade the harness or just plug them into the stock harness? :cheers: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 8, 2012 Share Posted April 8, 2012 I love my sealed beam silverstars, even with the OEM harness :dunno: Link to comment Share on other sites More sharing options...
knever3 Posted April 10, 2012 Share Posted April 10, 2012 I love my sealed beam silverstars, even with the OEM harness :dunno: I bought the silverstars for my Comanche, now that I have a '06 GC Hemi the silverstars are terrible comparitivly. It looks like I will be going with the Hella lights afterall. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 10, 2012 Share Posted April 10, 2012 Don't waste your time and money on the SS........I did. Care to elaborate. Did you upgrade the harness or just plug them into the stock harness? :cheers: The harness first, for sure. I recommend the harness upgrade for 2 reasons. One is you will have brighter headlights and an excellent upgrade path to follow in the future should you decide to. Secondly, the harness eliminates a high amp load of the headlight circuit running through undersized wires going through the headlight switch causing premature failure of the switch. You know when it's gonna fail, don't you? At night!! The supplemental harness is probably easier to install than a headlight switch is to replace. Not to mention the fact that many times the headlight switch plug melts down shortly before the switch does and further muddies the waters. Link to comment Share on other sites More sharing options...
SantaCruzComanche Posted May 4, 2012 Share Posted May 4, 2012 The supplemental harness is probably easier to install than a headlight switch is to replace. Not to mention the fact that many times the headlight switch plug melts down shortly before the switch does and further muddies the waters. What would you do if your plug did melt? can i rig in i new plug or do i have to switch the whole dash harness? I swapped out my headlight switch, but the plug for terminal I was melted, and I believe that's why half of my electronics only work when my headlights are on. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 6, 2012 Share Posted May 6, 2012 Plug ends are available at most auto stores. Or you can cut a couple of pig-tails from the JY. Don't crimp or wire nut or tape.............SOLDER! your connections. The harness we talk about here is at the rad support only, not under the dash. Link to comment Share on other sites More sharing options...
SantaCruzComanche Posted May 6, 2012 Share Posted May 6, 2012 I am referring to the plug that goes into the headlight switch Link to comment Share on other sites More sharing options...
kawaboy13 Posted May 7, 2012 Author Share Posted May 7, 2012 Is there a preference on the proper harness to upgrade with? I'm wanting to order but can't decide why some are differently priced? Are cheaper ones not enough upgrade? Thanks, John Paul Link to comment Share on other sites More sharing options...
kawaboy13 Posted May 8, 2012 Author Share Posted May 8, 2012 If I order the eautoworks harness can I run higher wattage bulbs or stick with 55/60? This is the harness: http://www.eautoworks.com/Putco-H4--900 ... D7540.aspx Link to comment Share on other sites More sharing options...
knever3 Posted May 8, 2012 Share Posted May 8, 2012 Order the Putco harness for $40 and the Hella e-code glass headlight housings with the Hella e bulbs. They are bright white. This is Susquehanna MotorSports's website. The H6054E is what you want. http://www.rallylights.com/detail.aspx?ID=744 Check out the review of my build on the last page. viewtopic.php?f=7&t=17711&hilit=first+restoration+project&start=120 Link to comment Share on other sites More sharing options...
kawaboy13 Posted May 9, 2012 Author Share Posted May 9, 2012 What is the difference in the xenon bulbs? Also do you think you can get a picture of your low beams on at night from like 50-100 foot? I want to see what other drivers will see. Thanks! Link to comment Share on other sites More sharing options...
