MississippiMJOwner Posted March 14, 2012 Share Posted March 14, 2012 I recently got my comanche back to going but it starts to shake badly when i got over 45 mph.the drivers side brakes were locked but they unfroze easily. It needs tires also . Would anyone know what it is besides a bad tire or brakes sticking? Link to comment Share on other sites More sharing options...
mvusse Posted March 14, 2012 Share Posted March 14, 2012 I'd start with the tires as the most likely cause. Link to comment Share on other sites More sharing options...
Eagle Posted March 14, 2012 Share Posted March 14, 2012 Tire balance. Link to comment Share on other sites More sharing options...
Paul Bruchal Posted March 14, 2012 Share Posted March 14, 2012 If not your tires, try Tie Rod Ends. I just fixed my death wobble replacing all of them. $77 is what I paid for 4 Tie Rod ends. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted March 14, 2012 Share Posted March 14, 2012 check all of these, C:\Users\store0575\Pictures\image-1636806076.jpg (copy and paste into search box) ^ also check for a loose steering box, worn out steering stablizer, bad wheel bearings, tire(s) out of balance, warped/bent rim, OR my personall favorite, if you have stock comanche rims, mud can build up on the inside of the rim causing an uneven weight, a good cleaning of all your rims inside and out would make for a simple test. i had the same problem, and a new trac bar solved most of the problem i was experiencing, now it just shakes at about 65+, instead of 55. I think its my control arms myself, but those are pretty expensive, and i've got 4 of em. Link to comment Share on other sites More sharing options...
carnuck Posted March 17, 2012 Share Posted March 17, 2012 Loose tracbar or wheel bearings Link to comment Share on other sites More sharing options...
Vintage Posted March 17, 2012 Share Posted March 17, 2012 New trackbar and tire balance did it for me. :thumbsup: Link to comment Share on other sites More sharing options...
SW86 Posted March 17, 2012 Share Posted March 17, 2012 track bar was the cause for me and that was even with bad ball joints and barely good tie rod ends..... also i don't know if you checked out the link to our local club down here but there are tons of people willing to lend a hand, locally I'm sure.. Link to comment Share on other sites More sharing options...
