Pete M Posted March 8, 2012 Posted March 8, 2012 XJs and wranglers can use them because they have short wheelbases and more severe angles on the driveshafts. MJs have more wheelbase and less angle and so the t-case drop usually just results in a loss of ground clearance. :thumbsup:
Blue88Comanche Posted March 8, 2012 Posted March 8, 2012 after having problems finding a stock x member for my AX-15 i had to get an aftermarket option, it has a 1 inch drop but was suppose to keep the same ground clearance but now i can't use my factory TC skid plate :doh:
camjeep3 Posted March 8, 2012 Posted March 8, 2012 I'm at about 6 or so inches. give or take. I have no need for one. Just as Pete said! :wrench:
mvusse Posted March 8, 2012 Posted March 8, 2012 Even on shorter wheelbase vehicles it should only be used as a temporary solution. It puts more strain on the engine mounts and makes the front driveshaft angle worse. Correct solution (when needed) is a slip yoke eliminator.
xjrev10 Posted March 9, 2012 Posted March 9, 2012 Even on shorter wheelbase vehicles it should only be used as a temporary solution. It puts more strain on the engine mounts and makes the front driveshaft angle worse. Correct solution (when needed) is a slip yoke eliminator. Agreed. My XJ with a 4.5 shortarm, does not have a sye or a t-case drop. I have no issues with it. But it never comes outa 4lo either.
mvusse Posted March 9, 2012 Posted March 9, 2012 Mine doesn't either, but does have a sye. Same length driveshaft front and back (and same as front on my MJ) means I only have to carry one spare.
carnuck Posted March 9, 2012 Posted March 9, 2012 The REAL correct solution is a NP208 AM with factory fixed yokes and wider chain than the NP231! (built to handle AMC V8s in Grand Wagoneers and Jtrucks) by itself Image Not Found
