Darren Posted January 30, 2012 Share Posted January 30, 2012 I tried searching but couldn't find what I was looking for. Build threads and or any threads related to a Renix to HO swap. I'm going to be taking that project on. I'm going to be acquiring an XJ for parts, so I'll have to mate the two harnesses. Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted January 30, 2012 Share Posted January 30, 2012 would you mate the harnesses or just rip out the Renix one and completely replace it with the HO harness? Link to comment Share on other sites More sharing options...
Jeepman Posted January 30, 2012 Share Posted January 30, 2012 When I did my Swap from Renix to HO I swapped XJ everything, interior harness and dash as well as underhood harness... But when using the HO Harness it will not plug into the MJ tail light harness so splicing would be required... The Second and third time I did the renix to HO swap I just used the under hood harness and swapped it just like I have done a 100 times with CJ and YJ HO conversions which is the easiest way to go... Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 30, 2012 Share Posted January 30, 2012 There is a write up in the DIY on how to adapt a MJ rear harness to the XJ (HO) dash harness. It is best to use all the HO stuff from under the hood and behind the dash. Very few of the HO plugs will plug into the RENIX era switches. I think the only one I was able to use was the ignition and the wiper control. Also the wiper motor used a different plug and had to be swapped out. Link to comment Share on other sites More sharing options...
neohic Posted January 30, 2012 Share Posted January 30, 2012 There is a write up in the DIY on how to adapt a MJ rear harness to the XJ (HO) dash harness. XJ dash harness to rear MJ harness wiring guides. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 31, 2012 Share Posted January 31, 2012 I tried searching but couldn't find what I was looking for. Build threads and or any threads related to a Renix to HO swap. I'm going to be taking that project on. I'm going to be acquiring an XJ for parts, so I'll have to mate the two harnesses. Are you hell-bent on using the HO harness and fuel injection? I've put HO engines into Renix vehicles using the Renix stuff a coupla times. Easy. Link to comment Share on other sites More sharing options...
