86customanche Posted January 6, 2012 Share Posted January 6, 2012 My blinkers have recently stopped working. :fs1: However, the lights still work, they just don't blink. When I hit the turn signal, nothing happens and when I turn on the hazard lights, the lights all come on but don't blink off. So it seems to me that a relay or something has gone bad preventing the lights to blink on and off but I can't find anything like that and I'm a little lost. :help: Link to comment Share on other sites More sharing options...
87Warrior Posted January 6, 2012 Share Posted January 6, 2012 The blinker and hazard flashers are located on the fuse block on the driver side. Also check for corrosion at the bulb sockets. Link to comment Share on other sites More sharing options...
86customanche Posted January 8, 2012 Author Share Posted January 8, 2012 The blinkers decided to blink last night but seem a little slow going. I'll check the sockets of all four corners sometime soon and maybe just taking the bulb out and reinserting will make a better connection and will work all the time. Link to comment Share on other sites More sharing options...
kawaboy13 Posted January 25, 2012 Share Posted January 25, 2012 Mine blink if my lights are not on, but the fronts will not blink when my lights are on? Any input there? :dunno: Link to comment Share on other sites More sharing options...
87MJTIM Posted January 26, 2012 Share Posted January 26, 2012 I just had my brake lights not working; turn signal and flashers worked fine. I traced the wires from the back to the front. Everything pointed to the turn signal switch. I replaced it ($25 at Pep Boys). Everything works fine now. Just a thought. Link to comment Share on other sites More sharing options...
Fezzik Posted January 26, 2012 Share Posted January 26, 2012 Just a thought, but I see you have an AX-15, Have you checked to see if your clutch master is leaking fluid on your fuses, I had mine leak and it caused my turn signals, hazards and brake lights not to work. Link to comment Share on other sites More sharing options...
86customanche Posted January 26, 2012 Author Share Posted January 26, 2012 Just a thought, but I see you have an AX-15, Have you checked to see if your clutch master is leaking fluid on your fuses, I had mine leak and it caused my turn signals, hazards and brake lights not to work. I have not checked. But would that be it? The lights worked more recently than not working. They just went out for about a week, very strange. Link to comment Share on other sites More sharing options...
Eagle Posted January 26, 2012 Share Posted January 26, 2012 Mine blink if my lights are not on, but the fronts will not blink when my lights are on? Any input there? :dunno: Bad headlight ground. The headlights are trying to ground through the blinker sockets. Or -- bad turn/parking light ground and they are trying to ground through the headlight circuit. Link to comment Share on other sites More sharing options...
kawaboy13 Posted January 29, 2012 Share Posted January 29, 2012 Where do I find these grounds? Thanks! Link to comment Share on other sites More sharing options...
pitbull4x4 Posted January 29, 2012 Share Posted January 29, 2012 My blinkers and hazards quick working also about 2-3 weeks ago. Stoped buy a shop that knows me. I tell them what is going on and he tells me to turn on the hazards and feel the relay. If I don't feel it clicking it is bad. I check it and no clicking. Go get new relays and they are working. So try it and see if you have a clicking. Good luck. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 29, 2012 Share Posted January 29, 2012 Where do I find these grounds? Thanks! The ground wire is under the driver's side tail light. Remove the tail light and check that the ground is good and clean. Link to comment Share on other sites More sharing options...
Eagle Posted January 29, 2012 Share Posted January 29, 2012 Where do I find these grounds? Thanks! The ground wire is under the driver's side tail light. Remove the tail light and check that the ground is good and clean. That's for the taillights. I believe the headlight and front parking light ground is behind the left headlight. Link to comment Share on other sites More sharing options...
carnuck Posted March 8, 2012 Share Posted March 8, 2012 Sometimes the ground inside the light socket goes bad. Link to comment Share on other sites More sharing options...
