1987 jeep comanche sport truck
4 cyl, 5 speed :yes:
with a turdy 5 in the rear
currently parked at one of my houses in the town over,
until june 16 ( finally get my full license, after my mishap back in september, page 10 on the never ending story (mary jane)'s build thread)
my 3rd Comanche owned :banana:
will be popping out into the town over to take more pictures ofcourse i know i know
:needpics:
but thats all you get for now 8)
this is a solid truck, few minor rust spots, but in over all good condition.
ive been watching this truck for months, and finally obtained it :D
(originally, i wanted to buy the bed only, but he woldnt let me, who knew i was to end up buying it)
not bad for five hundy :thumbsup:
i see the grill is nice and upside down. ill never get how you could put one on upside down. the design lines are there, match em' up people!! :dunce: :fool: but hey its only like ten screws to fix it
went into town today,
snagged some pics when i stopped by the house :yes:
tad bit sunburnt
typical interior, fairly clean to my standards :rotf:
still have the spare tire holder wrench!
Flintstones anyone?
new vent cover, seems like the old one got rubbed off
all set up for towing :D
original bed mat
not too bad underneath
more pics to come, i don't plan on doing much to this truck,
basic tune up,
will redo the clear coat in a while.
Great buy! Now I need to go to "page 10 on the never ending story (mary jane)'s build thread" to fill myself in on the story :cheers:
Just got through 12 pages of mary jane - she got pretty beat up. I did see that the 86 header bolts were in different spots than the 87+ years - good to know. :cheers:
more pics!
got er home
right now I'm wiring in speakers, cd player, amp and subs,
big mess of wires, didnt take any pics ,was too lazy,
when i get around to finishing the install ill take some more,
i need to replace the valve cover gasket and i will no more leaks either :thumbsup:
also found this puppy as i was gassing up
stuck around a bit for the owner, but they never showed,
oh well, maybe next time, geeze i really need to get my club swag some day,
apparantly imaginary CC cards arent good enough XD
so,
update for today.
wirring, not doing it the fancy dancy aircraft wire tie/solder yet, i need to find my final deck first,
subwoofer cut off switch
and now the fun begins
watch this video.
now, some pictures
don't think I'm street legal any more....
so off to town i go tomorrow, and get this installed,
i hope i don't get pulled over on the way there.
finally got around to wiring in some tunes.
isnt this supposed to be hooked up to something??
installed door boots,
havent built up the courage to hack my door panels apart yet to throw some speakers in,
I'm currently running with 2 ~3" ones mounted to the lower dash.
and ofcourse back massagers :rotf: :yes:
update
swapping out tires, and brakes
brake parts
old brake pads
uhh ohh, the bearing/hub style is different
off comes the hub cap
then the rotors
made a trip into town, because apparently they had some rotors, turns out, its the rotors in the 2nd picture o_O
so i threw the new brake pads on, checked the bearings, and re-assembled the brake's
new rubber :brows:
now I'm that much more street legal, all i need now is my windshield replaced
i bet that cop was profiling your @$$ hard and just had to think of something to get you for. classic a$$hole move
diggin the woofers man :chillin:
It is brake, not break.
I am not ragging on you at all. I am trying to keep you from looking foolish.
If his old ones were actually broken (as in not working correctly) then he wouldn't be as wrong. Never mind, it bugged me too.
thats what happens with no coffee in the morning :yes:
good eye :thumbsup:
so much for an anti build thread :rotf:
got around to flipping the grill right side up,
threw a 10 slot in there :yes:
removed the failed oxygen sensor.
the tools
the old sensor (2.5L) vs a good sensor (4.0L)
but they were in compatible, so i had to go out and buy a new one,
~$105 later... new sensor
old sensor vs new sensor.
installed.
took er out for some drivin,
found my own parking spot, :yes:
was up higher, but my lady friend was a bit scared XD
so here's a poser shot :rotf:
dropped her off today at the glass shop.
got my windshield replaced :yes:
and here she is,
will get better pics that are not from my phone,
when i have more to take pics of that is :thumbsup:
more pics of my new windshield :thumbsup:
now time for another update :yes:
took a trip to the local PnP
found these there
1986 2.1L diesel 4x4 dana 30 front with dana 35 rear and factory tow package.
jeep j10 pickup
and 2 grand wagoneer's
picked up some 97+ mirror's so off with the old
also fixed my truck running rich/miss firing.
p/o connected the MAP sensors vacuum line to a bolt o_O
plugged it into the correct spot, ran horrible for a few blocks, died lots, and then she started purring :drool:
Did you get the VIN for the registry off the 86?
:wall: :(
sadly, its the only thing i didnt think of to check for at the time.
bit of and update for today.
put some "bling" on the truck :rotfl2:
off with the old
on with the new
looks like it had a collision
half way done
and here she is
:jump:
more to come as always,
ill find an excuse to take more pics :thumbsup:
That J10 is a 3/4 ton J20. The D44HD front and matching D60 rear are good swap material even if the front is a pre-'80 pass. side drop. They are not as wide as most trucks. Swap a D300 x-fer onto the back of a 4x4 AW4, stick those axles on... :wrench:
I like the new mirrors. I see that swap in my future. Was it hard?
I need to persuade you to cut off a pass side cab corner off of one of those rust-free jumkers and ship it to Ohio for cheap... :D
not at all, easy direct bolt on,
and your in luck, i shall send you one once i make my pull trailer out of old rusty.
soo you know that saying, ittl fold like a taco?
well it folded like a taco XD
out comes the parts truck
the good the bad the ugly
half way installed
all done :jump:
more to come :thumbsup:
that is the nicest, roundest lil set of mirrors i've seen beside an mj in a long time. lookin good - and lookin good.
