for the better or the worse
better if mod it worse if leave it. port holes are different.
not true.
he said 95 on a 91.
same manifold. bolts right up, same identical thing.
not true.
he said 95 on a 91.
so ho to non ho is the same?
87-90 is the same
91-98 is the same
99-2001 is different, but will bolt on directly to a 91-98 head. you just may have to swap various brackets/sensors. these heads have better flow than the older HO's to offset stricter emissions requirements for those model years.
swapping the intake to a 99-up didn't do much for me.i swapped to a fresh ho head (93 model)and 99-up intake and newer tb all at the same time.besides fixing a leaky headgasket and replacing my noisy lifters it really didn't do anything.maybe the intake helps if you've got an oversize cam or head work but on a stocker it's not worth the money.
