turboxr Posted April 20, 2011 Share Posted April 20, 2011 Anything I'm missing? -V8 ZJ coils Upcountry if possible -Metric Tonne D44 -Metric Tonne leafs -Upcountry XJ/ZJ skids? -ZJ track bar/tie rod -Late XJ open loop coolant system -MJ bucket brackets -WJ brake booster, master cyl -WJ LCAs -ZJ rear disc setup -4 WJ full size spare wheels -XJ up country, or V8 ZJ sway bar, bar mounts, and sway bar links. -1989-97 Ford thunderbird V6 front coils and upper strut mounts... good for 3 1/2"-4" lift in front with similar spring rate -97 up XJ door weatherstripping -Eventually a complete rear ended 97up 4.0 4x4 5spd XJ lol Anything else? Link to comment Share on other sites More sharing options...
kro10000 Posted April 20, 2011 Share Posted April 20, 2011 Any MJ specific part you can find, cargo light, tailgate, taillights, etc. Also don't forget the MJ AMC 20, or XJ D44 Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 20, 2011 Share Posted April 20, 2011 Why the WJ wheels? They will not bolt on a MJ. Link to comment Share on other sites More sharing options...
offroader461 Posted April 20, 2011 Share Posted April 20, 2011 FYI ZJ's don't come in the upcounty package...only the XJ Link to comment Share on other sites More sharing options...
mvusse Posted April 20, 2011 Share Posted April 20, 2011 Do ZJ skids work on an MJ? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 20, 2011 Share Posted April 20, 2011 XJ up country, or V8 ZJ sway bar, bar mounts, and sway bar links. 1989-97 Ford thunderbird V6 front coils and upper strut mounts... good for 3 1/2"-4" lift in front with similar spring rate 97 up XJ door weatherstripping late 80's Camaro rear upper spring isolators... good as a budjet boost 2"- 2 1/2" late style front axle shafts with the bigger U-joints Nice GM steering wheels from like columned vehicles to replace/upgrade yours Lighted rearview mirror Link to comment Share on other sites More sharing options...
turboxr Posted April 20, 2011 Author Share Posted April 20, 2011 Are WJ's not the same bolt pattern? That screws me up. Darn it. Edit: original shopping list amended. Link to comment Share on other sites More sharing options...
turboxr Posted April 20, 2011 Author Share Posted April 20, 2011 FYI ZJ's don't come in the upcounty package...only the XJ http://www.kevinsoffroad.com/techarticl ... grade.html http://en.wikipedia.org/wiki/Grand_Cherokee Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 20, 2011 Share Posted April 20, 2011 Are WJ's not the same bolt pattern? That screws me up. Darn it. Edit: original shopping list amended. WJ is 5x5 bolt pattern, MJ is 5x4.5. WJ wheels will not work without adapters. Link to comment Share on other sites More sharing options...
valis Posted April 20, 2011 Share Posted April 20, 2011 Whenever I go to pick'n'pulls, I grab every single nut, bolt, screw, and random odd fastener I can get my grubby hands on. As long as I'm buying other parts, my yard doesn't care about what fasteners I grab and won't charge for them. I don't think I've owned an '84-'96 XJ or MJ that didn't have at least five screws missing from the interior dash panels. Link to comment Share on other sites More sharing options...
btm24 Posted April 20, 2011 Share Posted April 20, 2011 this may be of some help http://www.comancheclub.com/forums/viewtopic.php?f=3&t=29175 brandon Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 20, 2011 Share Posted April 20, 2011 here's a list put together on naxja http://www.naxja.org/forum/showthread.php?t=66012 Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 20, 2011 Share Posted April 20, 2011 And here's the info on the t-bird coils.. http://www.naxja.org/forum/showthread.php?t=68842 Link to comment Share on other sites More sharing options...
H3RESQ Posted April 20, 2011 Share Posted April 20, 2011 I see on original list you have both zj coils and thunderbird coils. I must say I'm interested to see how this turns out with two sets of coils under there, especially with how tight for space the front end already is..... :hmm: Just had to be a smartass. Looks like you will just run the bird coils Link to comment Share on other sites More sharing options...
offroader461 Posted April 20, 2011 Share Posted April 20, 2011 yea thats the Orivis edition with the upgraded suspension called upcounty...like i said the ZJ never came in the Upcounty package...i was stating this so you were wandering around looking at the ZJ's for an upcounty sticker on it somewhere...the Orvis editions are kinda hard to find anyway :cheers: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 20, 2011 Share Posted April 20, 2011 If you were looking at the WJ wheels to be able to have bigger wheels, 16 or 17 inch, yeah, like said, they won't fit, but if you find a set of steel wheels on a Chrysler 300, Dodge Charger, or Dodge Magnum, from 2005 on up, they are a direct bolt on, have the same backspacing as original, and the correct center hub... fit perfectly. Most of them are 17inch bullet hole steel wheels, but the ones on the police cars were 18 inch and had a 5 star pattern in steel that looks pretty good. A set of those would get you bigger wheels if you wanted them. Link to comment Share on other sites More sharing options...
87Chief Posted April 20, 2011 Share Posted April 20, 2011 Great thread, we must sticky. Link to comment Share on other sites More sharing options...
