SubSonic Posted April 12, 2011 Posted April 12, 2011 Should be by the hood latch area on passenger side fender of engine bay. Will have one wire on either side. It's a ceramic color.
Hubbell Posted April 12, 2011 Author Posted April 12, 2011 On the 2.5 there is no room like on the 4.0 that's why I was asking if another location is known?
ParadiseMJ Posted April 12, 2011 Posted April 12, 2011 Should be by the hood latch area on passenger side fender of engine bay. Will have one wire on either side. It's a ceramic color. the white thing
SubSonic Posted April 12, 2011 Posted April 12, 2011 On the 2.5 there is no room like on the 4.0 that's why I was asking if another location is known? Picture?
Hubbell Posted April 12, 2011 Author Posted April 12, 2011 I know what the ballast resistor is and where it's normally at but not on my 2.5.
SubSonic Posted April 12, 2011 Posted April 12, 2011 Did more research, looks like 87s didn't have them from the factory. A few got them as a TSB but chances are pretty good that you don't have one.
jimoshel Posted April 12, 2011 Posted April 12, 2011 Never really thought about it before so I went out and checked. MJ 2 '86 4 '87 4 '88 4 '89 None had the ballast resistor or any sign or evidence that they ever did. XJ'S. 7 XJ every year from '84 to '87 covered. No resistors. First resistor I found was in a '88. with 88 and 89 having them.
boosst Posted April 12, 2011 Posted April 12, 2011 Not trying to steal your thread but I have one on mine that is all busted up...what is it for?
Geonovast Posted April 13, 2011 Posted April 13, 2011 Not trying to steal your thread but I have one on mine that is all busted up...what is it for? It slows down the fuel pump after startup to reduce noise and allegedly lengthen the life of the pump. If they go out completely, the pump won't run, and the truck will die right after startup.
freakjeep93 Posted April 13, 2011 Posted April 13, 2011 i don't thing 2.5s had one. at least my 88 doesnt
Geonovast Posted April 13, 2011 Posted April 13, 2011 I know the MPFI 2.5s got them. Wouldn't surprise me at all if the Renix ones did not. Only one injector, ya know.
duster1971 Posted April 13, 2011 Posted April 13, 2011 Got a resistor on my 86 its on the firewall between map sencor and brake boster. And its a 2.5.
jpdriver1 Posted April 13, 2011 Posted April 13, 2011 Not trying to steal your thread but I have one on mine that is all busted up...what is it for? It slows down the fuel pump after startup to reduce noise and allegedly lengthen the life of the pump. If they go out completely, the pump won't run, and the truck will die right after startup. as a precaution to this (got stuck in the boonies), I carry in the tool box a short wire with a slip on connector on each end -- acts as a jumper till I can replace the bad unit -- or carry a spare resistor.
