i just recently got a MJ and i will be needing to get some parts for it. i was wondering if you all could help me generate a list of cherokee parts that will fit the MJ.
Everything from the doors forward is exactly the same (within the same group of years). Rear axles and brakes are also the same, but the rear axle mounts are different.
Not all years are interchangeable electrically. Chrysler changed to their own, in-house injection/ignition system in 1991, so pre-91 stuff related to fuel and ignition won't fit 91 and 92 -- regardless of whether it's an XJ or an MJ.
does it matter if the cherokee is 2 or 4 door if i want new doors for my MJ?
Yes, it does. 2-doors won't fit.
Also, '97+ doors won't fit without a matching '97+ striker plate welded in.
  • 13 years later...
9 hours ago, 87 Comanche dude said:
Do any GRAND CHEROKEE parts fit Comanches?
Depends on the part and the year of the Grand Cherokee. Body and interior parts are a no. Some mechanical parts and front suspension parts will interchange.
