JENSSEN Posted January 18, 2011 Share Posted January 18, 2011 Ok who has done this? Want to make sure all my bases are covered,.. the 89 Manche is a 2wd 4.0 Peugeot , I have a 4wd Peugeot of unknown condition so I am considering making one of 2,.. Now that being said I found a 99 Cherokee sport in the PYP and thought about using that one,. So what obstacles will I run into in either situation,.. Thanks in advance! -J Link to comment Share on other sites More sharing options...
Pete M Posted January 18, 2011 Share Posted January 18, 2011 I wouldn't bother with the Peugeots. sell them for scrap and put that towards an AX-15. :thumbsup: The Peugeot is notoriously hard to work on with no guarantee of success afterward. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 18, 2011 Author Share Posted January 18, 2011 I wouldn't bother with the Peugeots. sell them for scrap and put that towards an AX-15. :thumbsup: The Peugeot is notoriously hard to work on with no guarantee of success afterward. Thats why I was thinking the 99 tranny and t-case but what hoops will I have to jump through Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 18, 2011 Share Posted January 18, 2011 lots of tid bits here... 2wd to 4wd search Link to comment Share on other sites More sharing options...
Suuperman Posted January 18, 2011 Share Posted January 18, 2011 If the donor rig is a manual...you will need the flywheel, clutch, and then the tranny/t-case and driveshafts from the donor. If it is an auto...you will need the flexplate, tranny, t-case, and driveshafts. Of course the shifter/linkage will be needed in either case. If the donor is an auto...you will need an ECU from an auto the same year (or year range) as yours as well as the TCU for the tranny. It will be harder to swap BUT I have friend who did so successfully about 3 years ago. I helped some so I know first hand it works. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 18, 2011 Author Share Posted January 18, 2011 If the donor rig is a manual...you will need the flywheel, clutch, and then the tranny/t-case and driveshafts from the donor. If it is an auto...you will need the flexplate, tranny, t-case, and driveshafts. Of course the shifter/linkage will be needed in either case. If the donor is an auto...you will need an ECU from an auto the same year (or year range) as yours as well as the TCU for the tranny. It will be harder to swap BUT I have friend who did so successfully about 3 years ago. I helped some so I know first hand it works. The potential donor is a 99 Jeep Cherokee Sport 5spd (4Wd, 2Dr) , the recipient is a 89 MJ 4.0 5spd (2wd). So if I understand flywheel to driveshafts and all parts in between are required. :thumbsup: Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 18, 2011 Share Posted January 18, 2011 yep and you'll need a bushing from a 4.2 CJ7, someone chime in on this to make sure. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 18, 2011 Author Share Posted January 18, 2011 yep and you'll need a bushing from a 4.2 CJ7, someone chime in on this to make sure. Are you refering to the needle bearing in the crank to support the tranny input shaft? Link to comment Share on other sites More sharing options...
Geonovast Posted January 18, 2011 Share Posted January 18, 2011 If you put the 99 flywheel in your 89, your truck will no longer start. Your current flywheel will be just fine. Pukey used the same flywheel as the AX-15. In 91, the CPS windows were changed for the newer electronics. A Renix WILL NOT START with a HO flywheel and vice versa. The bushing you need to get a newer era AX-15 behind an 87-91 4.0 (yes I know renix is 87-90, but the pilot bearing sizes were not changed until 92) is from a 74 CJ with a 304, not a 4.2. Link to comment Share on other sites More sharing options...
ryno56 Posted January 18, 2011 Share Posted January 18, 2011 :agree: I put a 98 AX-15 in my 90 and thats all I needed. You'll likely need a crossmember/trans mount though. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 18, 2011 Author Share Posted January 18, 2011 If you put the 99 flywheel in your 89, your truck will no longer start. Your current flywheel will be just fine. Pukey used the same flywheel as the AX-15. In 91, the CPS windows were changed for the newer electronics. A Renix WILL NOT START with a HO flywheel and vice versa. Fweeew I was looking at that and thinking WTF ,.. I was confusidid,.. LOL I figured the flywheel had to stay the same,... Link to comment Share on other sites More sharing options...
Geonovast Posted January 18, 2011 Share Posted January 18, 2011 Yup, just leave your flywheel where it's at. Pukey and AX-15 used the same fly and clutch. You'll need to figure out something for the clutch hydraulics, 99 AX-15 will be external slave, and uses a plastic clutch line. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 18, 2011 Author Share Posted January 18, 2011 Yup, just leave your flywheel where it's at. Pukey and AX-15 used the same fly and clutch. You'll need to figure out something for the clutch hydraulics, 99 AX-15 will be external slave, and uses a plastic clutch line. So where in the clutch assembly do I start scavenging parts? Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 18, 2011 Share Posted January 18, 2011 304, yeah, thanks Geonovast I had to make a custom bushing for mine as I had newer 40 and older trans, a pain it was. :fs1: Link to comment Share on other sites More sharing options...
alleydog Posted January 19, 2011 Share Posted January 19, 2011 Is the crank sensor mounted in the same place on the bellhousing for a renix and the HO? Link to comment Share on other sites More sharing options...
Geonovast Posted January 19, 2011 Share Posted January 19, 2011 Is the crank sensor mounted in the same place on the bellhousing for a renix and the HO? Yes. But the sensor itself is different between the two, and the teeth on the flywheel that the sensor picks up are different. Renix flywheel needs to stay with a Renix CPS in a Renix controlled vehicle, and HO flywheel needs to stay with a HO CPS in an HO Controlled vehicle. Link to comment Share on other sites More sharing options...
JENSSEN Posted January 19, 2011 Author Share Posted January 19, 2011 Now I just need to see if I can get the ok from the boss to buy the parts :) Link to comment Share on other sites More sharing options...
dasbulliwagen Posted January 19, 2011 Share Posted January 19, 2011 Now I just need to see if I can get the ok from the boss to buy the parts :) Its easier to ask for forgiveness than it is to ask for permission! Link to comment Share on other sites More sharing options...
JENSSEN Posted January 19, 2011 Author Share Posted January 19, 2011 Now I just need to see if I can get the ok from the boss to buy the parts :) Its easier to ask for forgiveness than it is to ask for permission! Not in my case,.. :peek: Link to comment Share on other sites More sharing options...
JENSSEN Posted January 31, 2011 Author Share Posted January 31, 2011 Well I yanked the 99 XJ Tranny and got the plastic line and need to look into clutches for the old girl,.. figure if I am in there may as well pop a new one in ,... Link to comment Share on other sites More sharing options...
1tonMJ Posted November 12, 2011 Share Posted November 12, 2011 Posting to keep track of this thread. Currently putting an AX15, 231 and a Dana 30 in my 2wd Manche. Link to comment Share on other sites More sharing options...
